"Puzzle Creating"
All
1-2
3-11
Michael Gibson
17 Sep 2015 (3 of 11)
7619.3
In reply to
7619.1
Hi Frank,
> But after boolean "merge" I have to move the single objects a little bit to the outside to
> become a small gap between the objects.
The closest thing to this would be ExplodeMove like Pilou mentions:
http://moi3d.com/3.0/docs/moi_command_reference10.htm#explodemove
But the objects will move outwards from their overall bounding box center, it won't necessarily move them with a uniform gap between each piece. So to get a uniform gap you might need to use the manual movement that you've already been using.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frank (NITROXPRESS)
18 Sep 2015 (4 of 11)
7619.4
In reply to
7619.3
Hi all,
thank you very much !
The ExplodeMove is exactly what i have searched.
A uniform gap would be nice, but not necessarily needed.
Frank
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Max Smirnov (SMIRNOV)
18 Sep 2015 (5 of 11)
7619.5
Hi Frank,
check this example
moi.maxsm.net
EDITED: 7 Mar 2022 by SMIRNOV
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frank (NITROXPRESS)
19 Sep 2015 (6 of 11)
7619.6
In reply to
7619.5
Good workflow...
Thank you Max !
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Martin (MARTIN3D)
19 Sep 2015 (7 of 11)
7619.7
In reply to
7619.5
Hi Max,
what's the name of the font you used in the example?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
19 Sep 2015 (8 of 11)
7619.8
In reply to
7619.7
Hi Martin
it's GOST 2.304-81 font (common font used in russian design documentation)
http://moi.maxsm.net/share/GOST2.304-81.zip
moi.maxsm.net
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Martin (MARTIN3D)
19 Sep 2015 (9 of 11)
7619.9
In reply to
7619.8
Thank you Max!
-Martin
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
chippwalters
20 Sep 2015 (10 of 11)
7619.10
In reply to
7619.8
Thanks Max for sharing! I like that font :-)
Have you seen
MoI Interface Builder
? OR
PAT the 3D Humanscale Model for MoI
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
22 Sep 2015 (11 of 11)
7619.11
Cool the trick of the "Scale" ! Avoid some manual corners trimings! ;)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-2
3-11
