UnwrapCurve plug-in
 1-4  …  25-44  45-64  65-72
5136.65 In reply to 5136.62
Hi PILOU, I did not mean it is bad! Maybe I should say it feels different! (Please take a look at Zooen's work! (Ears of Wheat here: http://moi3d.com/forum/messages.php?webtag=MOI&msg=10315.1)
I wanted to replicate the vase!
5136.66 In reply to 5136.65
Vase is inverse than that ;)
Empty parts are full and vis versa ;)
5136.67 In reply to 5136.64
Hi Psygorn !
I don't know how Zooen done it, but this method is a possibility...
I drew a profil for the vase.
Made the vase by rotation (no cap)
I the vase cut to have something like you had (the top part)
With the same process seen before, I did a loft object with multiple curves (here in green)
I flow a Voronoi set of objects on this lofted object.
I use the vase (total vase, so perhaps have you to redo it because it has been cut before) with a Offset /Shell to have a volume
Next I use the new voronoi set in a boolean operation (difference) to make the holes.
I finished with some softerizer actions, fileting the holes and blending the top to have soft border .
Not so far from Zooen result.
Zooen's version is a slim vase, mine is a fat version.
Another method :)
Voronoi
Flat Lines
I just project the Voronoi...from Side View
Make a trim (manually)
Put a Shell
(if you kill the cap you have a vase! :)
et voilĂ  :)
EDITED: 15 May 2021 by PILOU
If you want like a true vase :) A little trick ;)
Of course you can fillet all internal small pieces "voronoi" (not made here) before projection!
(curious things on the up "golden voronoi" is just reflexion of material! :)
5136.70 In reply to 5136.67
Hi Phiro!
It looks promising :)
5136.71 In reply to 5136.68
Hi PILOU,
Nice models & nice renders!
your models look like perfume bottles!
Message 5136.72 deleted 31 Oct 2024 by 777RAVEN777
Show messages:  1-4  5-24  25-44  45-64  65-72
