Node Wish List
 1-6  …  127-146  147-166  167-186  187-206  207-226  …  407-425
9581.167
Hi Wayne,
The image circle packing looks great - this was under RHINO but no longer supported a node like this in MOI would be great.
Great work -
EDITED: 3 Jul 2022 by ALEXPOLO
9581.168 In reply to 9581.167
Hi Alex,
Ref:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.128
Your post from above had me searching high and low for a circle packing routine. The circle routine used on my program node is more of a pointillism. A weighted voronoi or stippling code would probably be closer to what you are looking for with images. The circle pointillism is great for vector graphic images. That is why it is still in beta. There is more that can be added to this node.
Thank you,
Wayne
EDITED: 1 Apr 2020 by WAYNEHILL5202
9581.169
Hi Wayne,
Thanks for looking into it - further development would be a great addon in the tool library for MOI.
Great work and thanks for contributing to its progression.
regards
Alex.
9581.170
connectPts Node
This node proposal would be analogous to and based on Michael's script found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2749.56
Happy Easter Everyone!
EDITED: 11 Apr 2020 by JFH
9581.171
New ExtendSrf Node release:
ExtendSrf is based on Michael Gibson's script:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9747.7
Thank you Michael!
Copy the ExtendSrf.js to the directory:
C:\Users\<UserName>\AppData\Roaming\Moi\nodeeditor\nodes\extensions
I would like to thank James for helping out with testing.
This is great way to divide solids into faces and shrink spacing between.
Wayne
Edit: Updated node
EDITED: 17 Jan 2021 by WAYNEHILL5202
9581.172 In reply to 9581.171
A sort of ExplodeMove ?
9581.173 In reply to 9581.172
More like an additive and retraction of the face edges without changing location. Michael described it as a surface offset.
9581.174 In reply to 9581.173
Excellent!
9581.175
Hi All,
It is a bit of an unusual method, but using Wayne's new node,
and using a sphere as a starting point, it's possible to form a compound
curved surface of the shell of a chair.
Thanks Wayne for your most recent contribution.
I'm hoping that coding nodes is a good technique to staving off cabin fever,
& we are it beneficiaries.
EDITED: 17 Apr 2020 by JFH
That's magical thing!
9581.177
BranchStructure node
The proposed node would generate venation patterns from seed points branching out to leaf points (attractors) using the "space colonization" algorithm.
Daniel Shiffman has done a coding challenge that serves as a good introduction to the method:
https://www.youtube.com/watch?v=kKT0v3qhIQY
Another good resource is Jason Webb's "Modeling organic branching structures with the space colonization algorithm and JavaScript" :
https://medium.com/@jason.webb/space-colonization-algorithm-in-javascript-6f683b743dc5
He demonstrates the difference between "Open versus closed venation" which is an option I have include in the info panel. The other option I have included is 2D vs 3D. 3D would work similarly, however with branches attracted to leaf points in 3d space, making possible the generation of natural forms such as tree, coral etc. This may be something that is left for later development.
EDITED: 1 May 2020 by JFH
9581.178
Hi All,
I have already alluded to this here:http://moi3d.com/forum/index.php?webtag=MOI&msg=9810.10 but in terms of implementation, rather than the generalised approach it may be better to have a purpose built "Reaction Diffusion" node.
React-Diffusion node
I am proposing a node that operates analogous to online app by @pmneila https://pmneila.github.io/jsexp/grayscott/
For our purposes the output would only need to be black and white, which hopefully would reduce the complexity of the coding. The proposed node would, similarly to Wayne's imgSampler convert greyscale to heightmaps, however instead of importing an image, it would be generated via an algorithm (grayscott) within the node.
Since this algorithms produce an evolving animated image there is a need to pause evolution at a desirable point so I have included an input for 1 to play & 0 to pause. There may be a more elegant solution of the inclusion of menu option in the info panel, or perhaps ideally a button on the node, itself.
I'm not sure if this is even possible without the addition of external js libraries. (I note that in the code for the online app link above that it imports three.js)
EDITED: 24 May 2020 by JFH
9581.179 In reply to 9581.178
Viewing page source yields: https://github.com/pmneila/jsexp
9581.180
Playing with a new node conversion of Max Smirnov's cloth script that he converted from the ThreeJS engine.
http://moi.maxsm.net/files/scripts/
My first attempt in animation on the Node Editor. Much to learn from Max's script.
9581.181 In reply to 9581.180
Does it works now with any volumes and not only a sphere ?
9581.182 In reply to 9581.181
Only spheres are in the original code. Will be testing other geometry types.
9581.183
Added node form and javascript code to message:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.180
9581.184
Finally releasing my ImgRGB first mentioned here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.165
The rgbquant.js library limits the style layers on the image.
ImgRGB send an RGB connection to OutRGB to reassemble the image to the style layers.
The OutRGB node only works with the ImgRGB node.
Thank you to James for the on going testing of the nodes I keep sending him... :-)
Wayne
Message 9581.185 deleted 14 Jun 2020 by JFH
9581.186 In reply to 9581.182
Wayne,
The cloth node is fantastic.......and mesmerising to watch.
"Only spheres are in the original code.
Will be testing other geometry types".
Although no doubt, working with other shapes would be usualful, I think your time would be better spent with the inputting of anchor points. This facility is included within Max's cloth script.
Anchoring points makes it possible to generate tent structure by setting gravity to a negative number:
I wonder if it would be easier to define, if instead of a rectangle input as you now have, it worked with a point array input (ie with MathsPoints or Points node input) In this way, the cloth point density is externally defined and anchor points selected with idSelect node.
Anyway, I know that this is no easy task, & what you done is just brilliant, I am just think about how this functionality may be integrated into the node ecosystem for procedural modelling.
Great work
EDITED: 14 Jun 2020 by JFH
Show messages:  1-6  …  107-126  127-146  147-166  167-186  187-206  207-226  227-246  …  407-425
