V5 Wish List
 1-16  …  457-476  477-496  497-516  517-536  537-556  …  637-656
10114.497 In reply to 10114.495
> So must each object as a Style (even a same color) with a different name!
> (if automatically possible of course)
> Here Object must be named Polo1, Polo2, Polo3
There is a script here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3334.2
That will make a style created for every named object, with the object assigned to it.
10114.498 In reply to 10114.497
Perfect for this rename them!
10114.499 In reply to 10114.477
@ Peer Maybe this can resolve your problem! ;)
Tips
Better if the original objects are Boolean Union and generator vertical line of Cylinder hidden
The complete easy final Process! :)
Of course each closed curve can be Style colorized and Named inside Moi!
for have directly named Layers inside Affinity V1! (no made here)
With this http://moi3d.com/forum/index.php?webtag=MOI&msg=3334.2
you can name automatically some Styles (so futur Layers) as you want
for have something more elaborated than "Default" following! :)
( Calque = Layer in French)
Intersection with a plane of the Imported PDF
else i have refound a Close Multiple Curves Command :)
https://moi3d.com/forum/index.php?webtag=MOI&msg=2752.1
EDITED: 22 Jan 2023 by PILOU
10114.500 In reply to 10114.499
Thank you for trying out some creative ways to attack the problem of getting closed paths!
Re:
I just tried this on a perspective projection of a more complex object, but the result of boolean union is that most lines get deleted, so maybe union only works for simple cases.
Re:
With more complicated line art this doesn't work for me. I get like 150 planar surfaces with triangular cutouts even though the line art doesn't have any triangles.
Re: Affinity Designer
I've already tried Affinity v2, but it's not good for me. I need a vector eraser, line width tool, and curve offsetting so that when there's a big area I can put hatching as a thin edging around the outside rather than having a large area of stripes that draws too much attention.
Illustrator has a well-known bug in its vector eraser and has a difficult to use width tool, which is why I don't use it for very much. But Affinity completely lacks a vector eraser and width tool, and has unreliable curve offsetting, so for my case it's not as good of a choice as Illustrator. In other words, neither Affinity nor Illustrator are very good for most of what I do, but for the part where I make closed shapes, Illustrator is better than Affinity because it can offset those shapes to make an edging / outline / annular shape around the perimeter.
- Peer
10114.501 In reply to 10114.500
@ Peer Just by hasard take a look at this niche program : White Rabbit CAD :)
It has some tools who maybe works for some figures! :)
https://www.tiesoli.com/whiterabbitcad/
You can send me some examples before / after wished for that i test with White Rabbit for the fun! :)
import 2D (pdf, svg) export SVG DXF
but Moi SVG, PDF --> Inkscape SVG --> White Rabbit
<< boolean union is that most lines get deleted, so maybe union only works for simple cases
Of course just boolean when "front faces" & lines are necessary...
EDITED: 23 Jan 2023 by PILOU
10114.502 In reply to 10114.501
Thanks for continuing to look for a solution. Attached is a 3DM along with SVG, AI, and PDF exports for testing.
- Peer
EDITED: 3 Mar 2024 by PEER
10114.503 In reply to 10114.502
@ Peer I will examine that! :)
@ Peer
I suppose all your files are from the initial 3DM and exported from Moi ?
Something strange!
I draw something in InkScape then export SVG ---> White Rabbit ...that works ! :)
I load your SVG file in InkScape (all is fine i see it) then export SVG ---> White Rabbit that don't work! :(
So I must investigate more! Be patient! :)
What is exactly the target wanted ?
Each face separated with a color for example, only closed curves of a file, both ? Other ?
EDITED: 24 Jan 2023 by PILOU
@ Peer ... SVG : it's a little nightmare! :)
I have maybe a process (in PDF) but we must hide these yellow lines by hand
so not sure that is a valid one that you have expected!
The Process some similar than previous !
From an Moi Object
- Boolean the solids
- Hide the lines no wanted
- Export as PDF View 3D for have any position wanted!
- New - Reload the PDF - View top (so we have the position of the original object in a plane ! )
- View Top - Intersect with a Plane
- Keep only the Object kill the rest
- the tricky Part! ExplodeMove (4)
- Select Curves (use the Browser) Kill them
- Select & Copy Move the Edges (use the Browser) become Curves! ) - Join these Curves = All curves are Closed!
- kill surfaces - put the closed curves at the original position
-UnExplode Move
- Export as PDF the closed curves View Top
- Open inside Affinity V1: colorize as you want all the Closed Curves!
et voilà! :)
to continue...but I leave the SVG for the moment too devious! :)
Else something like that :)
EDITED: 25 Jan 2023 by PILOU
10114.506 In reply to 10114.505
I tried to follow your instructions, but it doesn't really work for me. Here's what I see if I open closed_paths_test.pdf:
Also, even if this method works, it involves exporting an SVG from MoI, importing back into MoI to make closed paths, exporting from MoI again, and then combining the first export with the second export because the first export has multiple line widths that I need to keep. That's not really better than using Illustrator to make closed paths. I still have to ping-pong back and forth and at least with Illustrator the page size and position stays the same so I don't have to do a scaling and alignment step.
Here's what I need in the end:
1) Outline that is stroked outside of path rather than along center of path. When outline stroke is outside then edges meet corners properly:
But, when the outline stroke is centered then edges don't meet correctly but look offset:
A stroke can only be outside if the path is closed since open paths don't have an inside or outside.
2) block shading:
3) Hatch fill to indicate a cross-section plane:
- Peer
10114.507 In reply to 10114.506
I don't know if you have read the last Process because my computer crashes during its writing :)
Seems you don't make the Boolean and don't erase the inclined lines...before the first Export PDF !
How do you deal with these lines when you colorize?
But ok for the no Boolean if you want the "frame"!
I make all inside MOI only from your file PDF!
About the width of the lines that will be made inside Affinity after the final export PDF from Moi...
But I am agree if the erasing of the no wanted lines was automatic that will be a breeze! :)
Else I have all surface that you want (so no Boolean at the start process;) from the Trimming intersection with the plane! ;)
Even before to have the closed curves! Even before the Explode Move who will permit the close curves process!
You must have something like this
For make the curves close : Join them! (before the Un ExplodeMove)
The Un-MoveExplode...twice 0.5 because ExplodeMove was 4
That is finished! All Closed Curves are in position ready for be exported in PDF (View Top) to Affinity V1
And inside Affinity V1 the round intersections seems perfect ! If not that is not a big deal to connect them in the right place!
10114.509 In reply to 10114.507
Wow Pilou! I'm impressed by your creativity. I got your method working by using Trim rather than Boolean > Intersection.
I'm going to experiment more with your method tomorrow :)
- Peer
10114.510 In reply to 10114.509
My last one was without Boolean! ;)
But maybe there is more easy ...maybe just an intersection with a tricky plane ?
The only default that i see is the Lines to erase "manually"!
Because on a very complex object that will be very painful or impossible! :)
10114.511 In reply to 10114.509
@ Peer The mystery of the SVG file is quasi resolved! :)
It was a "," who must be changed in "."
So by Taron the creator of White Rabbit CAD! ;)
EDITED: 26 Jan 2023 by PILOU
Here the secret! :)
As I can't load any file SVG inside the White Rabbit CAD https://www.tiesoli.com/whiterabbitcad/
a 2D niche program for make clothes! :)
you must edit the svg file
Check the: viewBox="0 0 595,2756 841,8898"
Change it to be:
Check the: viewBox="0 0 595.2756 841.8898"
Now all works like a charm! :)
I don't know who is the guilty! :)
Inksape, Moi, White Rabbit Cad...
10114.513 In reply to 10114.512
It's a bug in MoI's SVG export, it should not be using localized number formatting for those values in the SVG file, I'll get it fixed up.
Thanks, - Michael
10114.514 In reply to 10114.513
Very cool...i can reload a Moi file SVG now if needing!
10114.515 In reply to 10114.511
Thank you for putting so much time and thought into this problem!
I tried out your method of trimming a plane with curves from SVG. It turns out there are a couple problems when I do this with a more complicated drawing. The first is that hidden line generation leaves behind a bunch of tiny lines in the SVG. Normally these aren't visible, but they're enough to cause tiny little cuts in the plane which then prevent joining the edge curves into closed paths. I tried removing the hidden line fragments, but it takes a lot of manual work.
The second problem is that, even after removing all the hidden fragments, trimming a plane with a jumble of curves isn't totally reliable. Some cuts get missed and sometimes some bug gets triggered and I see a bunch of triangular artifacts rather than a properly trimmed plane.
White Rabbit CAD looks good. For this task I'm probably going to stick with Illustrator since I already know how to use it. But, next time I have a sewing project, I'm certainly going to try it. Please thank Taron for me :)
- Peer
10114.516 In reply to 10114.515
in any case that tracked down a bug inside MOi ! ;)
White Rabbit is a very specialized program!
Its tools 2D are some ergonomic to use for draw curves or other geometric forms! :)
And smart UI like Moi! ;)
Show messages:  1-16  …  437-456  457-476  477-496  497-516  517-536  537-556  557-576  …  637-656
