 13-32
 33-52
 53
Hi Marc, please give the attached distribute plug-in a try, hopefully it will do what you were asking. Instructions for installing a plug-in
here.
It works with an object's bounding box and an axis direction of x,y, or z that you can pick, it will move objects in that direction so they have equal distances between their bounding boxes like this:
The first and last objects stay in place, and if there's not enough room to fit all the objects in the space between the first and last they will have equal overlapping distances instead like this:
Hope that will be useful for now!
EDIT: Jun 6, 2022 - updated Distribute script to have an option to set overall width to a specified value.
EDIT: Jul 22, 2022 - updated Distribute script to work with groups.
EDIT: Jul 24, 2022 - updated Distribute script to work in active construction plane.
 Distribute.zip
Distribute.zip
When objects are distributed can we have an option for have regrouped objets with o distance?
Or maybe it's yet integrated ? (but i don't find the trick with "Distribute" :)
Explode Move can make something for re-group but it's by "eyes", or numeric but not by snaping Bounding Box ! :)
And not sure that is easy to choose the good Origine Point with spheric or complex object!
PS Have also a no regular distribution can be also cool! (additive, multiplicative, Fibonacci, etc...)
Thanks, it looks great !
I'll try this as soon as I can.
Marc
Well, earlier in this thread I had asked:
    "If I understand correctly, the first and last one stay where they are and only the interior ones move?"
The one you're showing there has the last one moving, so it doesn't fit with the requirements.
But it is possible to make some modifications to the script so it will behave like you want, try saving Distribute.js and Distribute.htm to new files DistributePilou.js and DistributePilou.htm , then on line 48 there's a section of code that calculates the space, it looks like this:
	var total_space = sorted[sorted.length-1].bounds.min[dir] - sorted[0].bounds.max[dir];
	var occupied_space = 0;
	for ( var i = 1; i < sorted.length-1; ++i )
		occupied_space += sorted[i].bounds.max[dir] - sorted[i].bounds.min[dir];
	var available_space = total_space - occupied_space;
	var target_space_between = available_space / (sorted.length-1);
Comment out that entire section and replace it with just var target_space_between = 0, so it should look like this:
	var target_space_between = 0;
Then the only other change is a couple lines below that is the loop that moves the objects, it looks like this:
That loop needs to be adjusted to loop through sorted.length instead of sorted.length-1 , so if you take off the -1 so it looks like this:
	for ( var i = 1; i < sorted.length; ++i )
Then after that you should have a DistributePilou command that works like you wanted.
Excellent! Bravo!
With the native Align functions that will be very helping for grouping objects!
French Version :
http://moiscript.weebly.com/distributions.html
I believe that you must integrate this useful thing in the future V4! :)
(in Menu Align & Distribute? )
Function alone
With Align native. What a simplicity!
If someone could take the pilou version and add ui to allow a value entered for the space, that would make it "distribute" as i know it. That would be cool.
Hi BurrMan.
This is the updated version I wrote some minutes ago.
Please check if all works fine.
The file to download :
http://take.ms/qT3oZ
The UI's screenshot :
The numeric input accept also negative values.
Ciao.
Seems working fine for me! :)
Champagne!
The Manual button is tricky for have possibility (or not) to have the 0 distance (or numeric more or less) !
With a touch of native Align!
Of course a new Align Bottom on Front view will be necessary for align bottom the sphere!
French version tomorrow! ;)
PS Now a factor or something else for have a ruled distribution...will be a task!with
Here French Version ( with the error message when you select less than 3 objects! ;)
Will be named Distribution
Thanks Marco,
    Seems to work great!
Hey Marco,
    As an added note (not really a request) instead of the manual tick, if the box just readout the distance from the original method. Then you can type from there (and someone can add viewport picking to the value too. It would save a step!
Anyway, thanks again!
So with Flow function! :)
or Script Array
or Scale Array
Hi BurrMan.
You're welcome.
@You : "if the box just readout the distance from the original method."
I will try to add this feature later today.
See you.
Hi Pilou.
@You : "So with Flow function! :)"
Kepp in mind that for this situation, if you don't use the "Rigid" option of the Flow command, the resulting surfaces will be deformed.
That is they will not have the same topology of the input objects and you will have a resulting objects with much more control points.
See you.
P.S. Maybe, besides NodeEditor, it should be some other different ways to perform a a REAL distribution of a bunch of objects along a defined curve.
If remember correctly, the Max's VSeed + VCLone scripts will do the job.
I have to try.
See you.
Hi everyone.
I haven't found any good way to perform the "distribution and replication" of a bunch of objects along a target curve with Max's "Scatter" script family,
but maybe I did something wrong.
Anyway, speaking about the standard manual way, and not the Nodeeditor way, I've found a good solution using these bunch of commands/scripts :
UnwrapCurve, move, arraycurve, Flow, PointToMultiBolundsCenter (a simple script that places a point to a bounding box's center of an object).
http://take.ms/fbBCt
See you.
< if you don't use the "Rigid" option of the Flow command
Yes it's for that my Spheres are not Ellipsoïd 3D! ;)
Ps and the first time i use rigid! :)
There is cool but semi manual method for distribute as you want some Objects
Moveslicetopoint! :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=2749.36
Thanks for the tip Pilou, but for what I remember about Moveslicetopoint, it's not meant to be used for distribution of objects along a path curve.
It's for other purposes.
Anyway, thanks for the reminder and I'm glad to know that my latest video tutorial was useful for you :)
Bye!
Thanks for taking the time to cook this Michael, works A-1.
Excellent Ideal Pilou about the fixed distance, thanks Marco !
I would definitely see these options in the align panel, just as a button that unfold the options once you press it.
Perhaps randomize command would also be nice to have in there too!
-Happy camper
Hey Marco,
The link no longer works... do you still have the file set?
If so, would you post them both here please?
Mindset
 13-32
 33-52
 53
