Full Version: Voronoi Script or plugin
Show messages:  1-8  9-28  29-48  49-68  69-88  …  189-198
5 Sep 2015   [#9]
Forget to say. You can select existing points before the script run.
Double click on title -> reset points
>>Will be cool if you can automatize this :) (or maybe yet exist something for this sort of triming ?
It's possible, but it will consume a lot of processor resources. Yes, it will be better to use boolean isect.
Brian
Yes. ( Voronoi + Plane ) -> Boolean merge -> Explode -> Exturde (tapered) -> Flow
5 Sep 2015   [#10]
<< Double click on the title
Hidden function! :)
5 Sep 2015   [#11] In reply to [#10]
Every my script has similar hidden functions :)
5 Sep 2015   [#12]
Very cool and speed!
Message 7177.13 was deleted
5 Sep 2015   [#14]
Max you continue to IMPRESS! Just wow and THANKS!!
Click IMAGE to view full size.
6 Sep 2015   [#15]
Fibonacci script + Voronoi
7 Sep 2015   [#16]
http://moi3d.com/forum/index.php?webtag=MOI&msg=539.38 ;)
7 Sep 2015   [#17]
<< ( Voronoi + Plane ) -> Boolean merge -> ExplodeMove -> Extrude (tapered) -> Flow
don't work for me ! (in fact yes but I must kill the general bound edges)
( Voronoi + Plane ) -> Trim > Kill Curves -> ExplodeMove -> Extrude (tapered) -> Flow
works!
11 Sep 2015   [#18]
Voronoi works with 3D points, but the points do not have their z values changed to zero.
They can be projected to the top view.
7 Feb 2016   [#19] In reply to [#6]
Dear Max,
i am new here and i am from Germany.
Sorry about my english.
I buyed the programm moi3d because
i was thinking that voronoi is working
.Now i see that i have to install your script.
But i am not a computer freak.
and i dont now how to do it.
And what i have to do?
I think i have to download you zip
voronoi.v.0.6.2015.09.05.zip
but what i have to do after it.
Open the zip ist not working
where did i have to install it.
Please help me because here nobody
makes a simple manuel step by step to
install a scrip.
Thanks Oliver
7 Feb 2016   [#20] In reply to [#19]
Hi Daiber,
Unzip the zip file, in a directory other than Program Files (x86), (due to windows 7 copy protections). Copy the _Voronoi.htm and .js files to your moi3 commands folder. The path will be similar to C:\Program Files (x86)\MoI 3.0\commands.
Then, open MoI, and set up a shortcut, under Options / Shortcut keys. Chose a Key, and enter the command as _Voronoi.
Brian
7 Feb 2016   [#21] In reply to [#19]
Hi
Some pictures if it can help to illustrate the BRIAN' explanation .
Clic on pictures 3 and 4 to animate.
Chri
7 Feb 2016   [#22] In reply to [#14]
Did you use an offset and extrude to get the Voronoi diagram to look like a grill. If so, how did you do it? I can't seem to get the offset to work.
7 Feb 2016   [#23] In reply to [#19]
Hi Oliver, also there are some instructions on how to install a plugin on the FAQ here:
http://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
9 Feb 2016   [#24] In reply to [#22]
Hi Wlawton,
you could do it like this. When you have your 2D Voronoi Diagram make of each cell and individual closed one and then draw with the curve tool at each point of a cell a closed line. Once finished offset those inwards. Later extrude all of them.
Here's a quick picture attached to show you what i mean.
9 Feb 2016   [#25] In reply to [#24]
I think a video I saw of the tutorial mentioned a script called "fat lines", but no mention of where to get it. Does anybody know?
9 Feb 2016   [#26] In reply to [#25]
You can get it from Max's file archive here:
http://moi.maxsm.net/media/files/
Message 7177.27 was deleted
Message 7177.28 was deleted
