Full Version: Voronoi Script or plugin
Show messages:  1-3  4-23  24-43  44-63  64-83  …  184-198
13 Jan 2015   [#4]
Circumcenter
http://moi3d.com/forum/index.php?webtag=MOI&msg=4833.1
13 Jan 2015   [#5]
Thanks. I'll play around and see what I can do.
5 Sep 2015   [#6]
Wrote this script today. It's based on Ivan Kuckir's Voronoi JS library. (http://blog.ivank.net/voronoi-diagram-in-javascript.html)
It is not a final version, but it works pretty well.
5 Sep 2015   [#7] In reply to [#6]
Cool!
French version : http://moiscript.weebly.com/scripts-de-max-smirnov.html
Don't work with any closed plan lines figure, only a rectangle ?
(Sure I can trim something after the process ;)
Will be cool if you can automatize this :) (or maybe yet exist something for this sort of triming ?
Edit ! Yesssssssssssss the Boolean Inter! :):):)
Select Voronoi Name it, Select Polygon name it
Select Voronoi's lines
Call Boolean Inter
Click Polygon
Et voilĂ !
5 Sep 2015   [#8] In reply to [#6]
Very cool.
So was Flow used, along with some explode move script, for the example?
5 Sep 2015   [#9]
Forget to say. You can select existing points before the script run.
Double click on title -> reset points
It's possible, but it will consume a lot of processor resources. Yes, it will be better to use boolean isect.
Brian
Yes. ( Voronoi + Plane ) -> Boolean merge -> Explode -> Exturde (tapered) -> Flow
5 Sep 2015   [#10]
<< Double click on the title
Hidden function! :)
5 Sep 2015   [#11] In reply to [#10]
Every my script has similar hidden functions :)
5 Sep 2015   [#12]
Very cool and speed!
Message 7177.13 was deleted
5 Sep 2015   [#14]
Max you continue to IMPRESS! Just wow and THANKS!!
Click IMAGE to view full size.
6 Sep 2015   [#15]
Fibonacci script + Voronoi
7 Sep 2015   [#16]
http://moi3d.com/forum/index.php?webtag=MOI&msg=539.38 ;)
7 Sep 2015   [#17]
<< ( Voronoi + Plane ) -> Boolean merge -> ExplodeMove -> Extrude (tapered) -> Flow
don't work for me ! (in fact yes but I must kill the general bound edges)
( Voronoi + Plane ) -> Trim > Kill Curves -> ExplodeMove -> Extrude (tapered) -> Flow
works!
11 Sep 2015   [#18]
Voronoi works with 3D points, but the points do not have their z values changed to zero.
They can be projected to the top view.
7 Feb 2016   [#19] In reply to [#6]
Dear Max,
i am new here and i am from Germany.
Sorry about my english.
I buyed the programm moi3d because
i was thinking that voronoi is working
.Now i see that i have to install your script.
But i am not a computer freak.
and i dont now how to do it.
And what i have to do?
I think i have to download you zip
voronoi.v.0.6.2015.09.05.zip
but what i have to do after it.
Open the zip ist not working
where did i have to install it.
Please help me because here nobody
makes a simple manuel step by step to
install a scrip.
Thanks Oliver
7 Feb 2016   [#20] In reply to [#19]
Hi Daiber,
Unzip the zip file, in a directory other than Program Files (x86), (due to windows 7 copy protections). Copy the _Voronoi.htm and .js files to your moi3 commands folder. The path will be similar to C:\Program Files (x86)\MoI 3.0\commands.
Then, open MoI, and set up a shortcut, under Options / Shortcut keys. Chose a Key, and enter the command as _Voronoi.
Brian
7 Feb 2016   [#21] In reply to [#19]
Hi
Some pictures if it can help to illustrate the BRIAN' explanation .
Clic on pictures 3 and 4 to animate.
Chri
7 Feb 2016   [#22] In reply to [#14]
Did you use an offset and extrude to get the Voronoi diagram to look like a grill. If so, how did you do it? I can't seem to get the offset to work.
7 Feb 2016   [#23] In reply to [#19]
Hi Oliver, also there are some instructions on how to install a plugin on the FAQ here:
http://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
