Skewing a shape
4382.3 In reply to 4382.1
Hi Mark, like Danny shows you need to turn on control points with Edit > Show pts and then you can manipulate them to make adjustments.
The Transform > Align command can be handy to use for adjusting points to be in a straight vertical or horizontal line:
http://moi3d.com/2.0/docs/moi_command_reference8.htm#align
Also if you want to have a curved piece stay more rigid in shape instead of having it deformed, you can use Edit > Separate to break it into segments, then use a combination of scaling + rotation to reposition it. The Transform > Orient > Line to line command can be useful for doing that since it combines scaling and rotation together with just a couple of picks:
http://moi3d.com/2.0/docs/moi_command_reference8.htm#orientlinetoline
