Hi Andrew, that is using the Object Library plugin from Max Smirnov which is a part of the CustomUI extension. You can get it at:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
> Another thing is, will this script work in Moi v4? I dont want to get used to it, and then choose beetwen
> older version of software or do not having this great addon.
Yes, there is a version of CustomUI that works with MoI v4.
> The last thing is, that after all this years Moi should have a clean webpage with
> list of all usefull scripts, documentions etc.
If you go to the "Resources" link on the main web page, there are links to collections of the most frequently used scripts here:
I do want to make it easier to browse and install script in the future, I have some ideas on having a script browser that you would pull up in MoI that would connect to an online script repository. It will be quite a lot of work to make that though so I'm not sure when it will happen.
