Running Scripts in Moi3d
8963.1
Hello Everyone,
I went to Max website and DL some scripts , How do you run it on Moi3d v3 win, Is there a specific addon to install so I could run the script . I put the scripts in the command folder now what do I do?
Need help with this if anyone can help I greatly appreciate it .
Thank you
Adan
8963.2 In reply to 8963.1
Hi Adan, there are some instructions for installing scripts in the FAQ here:
http://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
It sounds like you've done the first step of copying the files into the commands folder. Once you have done that then the easiest way to trigger it is to set up a shortcut key with that command name. Also another way to run it is to press the Tab key, type the command name and then push Enter.
8963.3 In reply to 8963.2
Michael,
Thanks for your quick response , I got it working . By any chance where can I get info on the node editor and custom ui setup in moi3d version 3 Win .
Thank you so much for your support .
Adan
8963.4 In reply to 8963.3
Hi adan, CustomUI is here: http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1 and I think starting point for the node editor is on the wiki: http://moi3d.com/wiki/Nodeeditor
