Dimensions again
All
1
2-4
Frenchy Pilou (PILOU)
30 Jan 2018 (2 of 4)
8800.2
In reply to
8800.1
You can Press TAB and write _dimensions or _Dimensions but without space !
or make a Shortcut as usual and write _dimensions on the second column
EDITED: 30 Jan 2018 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
r2d3
30 Jan 2018 (3 of 4)
8800.3
In reply to
8800.1
To install custom scripts in Moi have a look here:
http://moi3d.com/wiki/FAQ#Q:_How_do_I_install_a_plug-in_script.3F
after this you can add a shortkey, or using the command bar like Pilou sad to use the script
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Claus
31 Jan 2018 (4 of 4)
8800.4
In reply to
8800.3
Merci All !
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1
2-4
