V4 beta Nov-13-2017 available now
 1-12  13-32  33-52  53-72  …  213-231
8675.13
Michael, congratulations on launch! Exciting stuff. A quick 10 minute pass (no custom ini, just playing) and it all looks GREAT! Looking forward to spending more time playing soon :-)
8675.14 In reply to 8675.11
> << also linked to from the download page on the main web site.>
> Don't see any link of that! ;)
It seems to be there ok... Maybe hit reload on your web browser?
8675.15 In reply to 8675.14
Yep : reload was the trick! Sorry for the disturb! :)
8675.16 In reply to 8675.1
Hi Michael!
Thanks a lot for your efforts !!!
This is a brief report :
My laptop config is :
Windows 10 Pro 64 Bit English
i7-4790K 4.0 - 4.4 Ghz
32 Gb Ram 1600 DDR3
Nvidia Quadro K3100M 4Gb 768 Cuda Cores (Driver Version 385.69)
SSD Samsung 512 GB
1) Just downloaded and installed. No problem at all :)
2) All V3 shortcut keys works properly with the V4!! Thanks!
3) I spent few minutes playing with the new V4.
I downloaded some 3dm files.
4) Loading is OK
5) To stress CPU/GPU I'm using a 5 degrees mesh angle
6) I recorded this video to show you V4 running on my laptop.
I noticed these things :
A) It seems that there is no speed gain compared to V3, both in terms of loading and in terms of navigating the viewports (:
B) It seems that V4 has the same issue of displaying "fake edges" in some part of the models
C) As you can see in my video, the antialiasing of edges and above all of surfaces's boundaries is unsatisfactory.
I didn't touch anything in my Nvidia Control Panel.
I'm using V4 as is.
This is the video : http://take.ms/ywed7
7) I have also copied all my custom commands/scripts to the new V4.
In next days I will let you know what works and not works correctly.
Thanks a lot again.
I stay tuned.
Ciao.
8675.17 In reply to 8675.1
p.s.
My laptop has a simple Full HD (1920x1080) panel.
Just some example screenshots :
Ciao!
8675.18 In reply to 8675.16
Hi Marco, thanks for testing it!
That's expected right now and it's good in fact that there isn't any regression. I haven't had a chance yet to finish the work on speed improvements by making use of lots of available VRAM, there is some of the infrastructure in place for it but that's something that I will be working on more once things stabilize. Please remember this is only the first beta and does not contain everything that I want to have in the final v4 release in it as of yet.
That's expected, it should behave exactly the same as V3 right now.
Same thing here, it's expected to behave the same as MoI v3 at this moment. But it will not be difficult for me to add in an option to enable MSAA once the initial stabilization is done.
Thanks, - Michael
8675.19 In reply to 8675.18
Ok Michael!
@You : "...Please remember this is only the first beta and does not contain everything that I want to have in the final v4 release in it as of yet..."
Got it! :)
I stay tuned.
I will let you know my next test results ASAP (I think only late at night...)
Ciao!
Here the FrenchStrings.txt updated! ;)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/frenchstrings.txt
just a little thing : seems there is no more "line break" when edit with the normal Windows NotPad !
works fine with NodePad ++
EDITED: 13 Nov 2017 by PILOU
8675.21 In reply to 8675.1
Firstly, thanks for the V4beta! I look forward to big things
with my favourite app.
As already established, most tools don't work on a mac,
but I wanted to test custom UI and node editor.
As you can see both run with the beta, but this error
occurs when pinching on trackpad in NE.
Also some navbar buttons have disappeared.
Hope this helps
EDITED: 15 Jun 2019 by JFH
8675.22 In reply to 8675.21
Also, when I install Custom UI, I lost icons on the footer (File, Save, Undo, etc...) . (as we see in James screenshot)
8675.23 In reply to 8675.22
Hi Finema, for lost icons with CustomUI, that's because installing CustomUI writes a MoI v3 version of CommandBar.htm in place of the V4 one which is slightly different. So you can't install it by copying the CommandBar.htm directly like you did with v3, either you've got to splice the extra stuff into the new CommandBar.htm or wait for a v4 version of CustomUI.
In general since the UI is slightly different from v3 you can't just copy entire v3 customized UI files into v4, you've got to merge changes in with the new v4 structure.
8675.24 In reply to 8675.22
More info on CustomUI missing icons - the missing ones are the ones that used the res:// protocol for getting the icon from moi_lib.dll binary resources. MoI v4 doesn't have any of those anymore and doesn't have a res:// protocol handler anymore so that's why those are missing. You'll need to splice in the v4 buttons for those ones instead of using the v3 buttons.
8675.25
Hello,
Congrats Michael! What a milestone! Big day for you and Moi3D users. Thanks a lot for your effort.
I have 2 questions:
1. v4 will live side by sie with v3, or will replace it?
2. There is any kind of migration soft for scripts? I believe v3 had some sort of batch copying scripts (and/or short keys)?
Carlos
8675.26 In reply to 8675.25
Hi Carlos, thanks! V4 can be used side-by-side with V3 and in fact I'd recommend having them both especially at the moment while there are rough edges being worked out. But it is my goal to stabilize v4 rapidly and get it to full parity with v3.
For migration it's just any custom scripts that you will need to copy over from the v3 commands folder into the v4 commands folder. You can copy the contents of the entire folder over and just say no to overwriting. Shortcut key definitions will come over automatically since they're stored in moi.ini and v3 and v4 will use the same moi.ini file.
Ok, so for the Mac version I'm getting close to solving it, I didn't catch it because it only gets messed up when packaging it up for deployment. The way library loading is organized on the Mac is pretty different from what I'm used to. Just part of the brave new world of a native Mac build...
8675.28 In reply to 8675.27
OK Michael !
I'll wait for the custom Ui v4.
In fact I just want a button in the interface with which I can run extra scripts. (it's OK, i've just add a line code in CommandBar.htm V4)
I love the new clean interface of V4 on my Imac retina !
EDITED: 13 Nov 2017 by FINEMA
8675.29
Hello,
Thanks Michael for this 64bit flavor !
I did a couple of test to push the mesher :
Engine V-Twin, by Aled J Taylor : +- 23M Ngones !!!
[LINK]https://grabcad.com/library/engine-v-twin-4-valve-heads-1[/LINK]
LAMBORGHINI AVENTADOR, by Fateh MERRAD : +-8M Ngones
[LINK]https://grabcad.com/library/lamborghini-aventador-lp700-1[/LINK]
EDITED: 16 Jan 2023 by PAQ
8675.30 In reply to 8675.29
Hi PaQ.
Thanks a lot.
I was just about to ask Michael some url where to download some huge model for testing.
8675.31 In reply to 8675.28
Hi Finema,
Yeah it's kind of funny how it works out from really gross to really nice there. The text in particular.
I've managed to track down what was going wrong with those commands on the Mac version and will be able to have a fix tomorrow.
8675.32 In reply to 8675.29
Hi PaQ, awesome looking results! Did you happen to look at how much RAM was being used for those?
Show messages:  1-12  13-32  33-52  53-72  73-92  …  213-231
