How to delete overlapping Points?
B-W-Design
18 Oct 2017 (1 of 5)
8634.1
I have created a Vectorfile in Illustrator. When i open this file in MOI there are hundrets of overlapping Points. Is there a way to automaticly remove those Points?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
18 Oct 2017 (2 of 5)
8634.2
In reply to
8634.1
Wow that's a lot of them. I'd give the Rebuild command a try:
http://moi3d.com/3.0/docs/moi_command_reference10.htm#rebuild
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
B-W-Design
18 Oct 2017 (3 of 5)
8634.3
In reply to
8634.2
Oh what a powerful Command!
But in the corners it's not realy useable, cause you get round corners after use.
But, in most cases it's realy well!
Thanks alot.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
mkdm
18 Oct 2017 (4 of 5)
8634.4
In reply to
8634.3
Hi B-W-Design.
@You : "...But in the corners it's not realy useable, cause you get round corners after use..."
I don't see this problem with curves imported from Affinity Designer. Corners remains corners also after a Rebuild.
Cheers.
Marco
mkdm
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
18 Oct 2017 (5 of 5)
8634.5
Separate for have curves and straight lines separated so you can rebuild only curves! :)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
