folding knife
 1-9  10-23
8580.10 In reply to 8580.9
Hi chippwalters!
Thank you very much for this very interesting tutorial on "pipeline" (or "workflow").
Very interesting.
Bye.
8580.11
@ chippwalters Thank you man! Awesome tutorial as usual. I thought of exporting all the parts separately actually and I will do it eventually if I can't solve it any other way. It's an annoying process though, in particular for more complex models.
In your tutorial about the camera drone you imported the whole model into 3d Coat and it worked just fine. Is there a reason why you changed your workflow?
8580.12 In reply to 8580.11
I changed it because I wanted to be able to quickly combine sets of objects in 3DC to be able to distress groups of models together.
In order to bake normals onto simpler geometry in Substance Painter, it's best to have a bake target for each material. So for a product like a knife which has two materials (a blade and a sheath), you would need two bake targets.
I don't know why you would want to voxelize your knife unless you wanted to add distress or create different bake sets.
The drone example didn't need baking, so I exported it as one object with separate meshes.
A quick test and I was able to successfully export 2 meshes at the same time into the Paint Room of 3DC and maintain their separate meshes:
8580.13
@ chippwalters I'd like to import the knife model into 3DC to smooth some edges I can't fillet in MoI and to make some experiments with texturing. No problem, I'll export the different parts separately. Thank you for your help!! :D
8580.14
This is one way of doing it.
https://www.cgtrader.com/profile/tutorials
8580.15
@ keith1961 I can't open the page! :( (I think registration to the website is required to open it).
8580.16 In reply to 8580.9
Hi Chipp .
Sorry to try to contact you via this forum
I read an article written by you recently and wished to ask you some questions about software
I can't find the thread.
I am reachable at eric@ericdesignstudio.ca
If you have the time and inclination please send me a contact method
thanks,
eric
8580.17 In reply to 8580.11
In 3dC, during import object, select "W/O voxelization".... This will import separate named objects on their own layers... You can then voxelize layers 1 by 1 if you want voxels.... This is good too because you don't always want "4 million polys" to get detail on a box", like you may need for a blob of some sorts... Each object can have it's own poly count settings...
8580.18 In reply to 8580.15
8580.19 In reply to 8580.10
Hi Marco
Do you know why the Rocket forum has gone quiet? I want to know how to constrain extrude to 90 degrees but there seems to be nobody to ask.
Best wishes
Keith
8580.20
@ BurrMan @keith1961 I hadn't checked "Import w/o voxelization" nor "Import to separate instances". I've just tried with another model and it works!! Thank you guys!!!
8580.21 In reply to 8580.19
Hi keith1961.
@You "...Do you know why the Rocket forum has gone quiet?..."
Good question. Also I'm wondering...
I'm going to echo this question also on NVIL's forum that is managed by Istonia (the creator of R3F along Samardac)
@You : "...I want to know how to constrain extrude to 90 degrees..."
What exactly do you mean ?
If you're talking about "Normal Extrude", this is very simple in R3F.
"Normal Extrude" in fact already extrude a face or a group of faces to 90 degrees.
It's very simple.
1) Pick the face(s) you want to extrude
2) Hit the "a" key
3) With that key pressed push the middle mouse button and start to drag (you can also release the "a" key after you have started to drag)
4) release the middle mouse button when finished
And in this way you can perform a "extrude normal".
Bye!
8580.22 In reply to 8580.21
Hi Marco
Maybe Samardac is on holliday?
Ah... the 'A' Key i was trying shift, space, ctrl
8580.23 In reply to 8580.22
Hi keith1961.
You're welcome.
@You : "...Maybe Samardac is on holliday? ..."
LOL :) I don't know...I don't live with Samardac :)
Anyway I asked on NVIL's forum about the silence of R3F's forum.
Bye!
Show messages:  1-9  10-23
