Suggestion: MOP Booleans
 1-2  3-22  23-34
8509.23 In reply to 8509.21
"""""""""That strategy wouldn't fit with my own personal goal of avoiding management and administrative type duties as much as possible. """"""""""""""""""
Lol..... Sometimes, you just can't pay me enough money!!!!
Life is short. Onward!
And small is beautiful! ;)
8509.25 In reply to 8509.20
>> If Spaceclaim does what you need, you should get it, you can use MoI in combination with Spaceclaim quite well. I think it supports copy and paste between MoI using the Rhino clipboard format although I'm not sure if that's still active in the current version.
Yeah but Spaceclaim is super expensive. Even so i really like Moi3D and how everything works and looks...and i gladly paid for it even if i could choose Fusion360 for example which i didn't quite like (workflow related mostly in general).
The main point here is few very important features that Moi3D should have or should be able to do. I really don't need massive amount of features, i can do a lot with just what Moi3D has but it would be great if those features are really not limiting.
What i mean by that is that Moi3D is aimed mostly for artists and "concept modeling", fast and fun, but the thing is that you are losing quite a bit of that fun when you want, for example, fillet something (hah, that fillet again..lol) and it just can't do it in certain situation and fails as soon as things get a bit more complex. Or an single edge is getting in a way and fillet fails (where other software solutions just make it across the edge no problem) so you have to go though elaborate, tedious and often more advanced techniques to get rid of that pesky edge so that fillet can work. Easy to do if you have some simple planer surface but very often you just can't delete face and use "Planer" - done.
I understand though that it's not everything easy to do, cost money and takes a lot of time especially when you are doing all the work alone! I am doing also a bit of scripting myself and i know very well know how it is like when people request to just add that "small" little thing. :)
Cheers.
8509.26 In reply to 8509.25
One thing it can teach you is to avoid putting that "problematic edge" there in the first place. A valuable skill in nurbs modeling.
With regard to the mamoths who can just "eat through" fillets like theres no tomorrow, that can be a "bad habit" also. So in a "manufacturing arena" the gobbled up area can be ARBITRARY and even DIFFERENT with various packages. Not a good thing when trying to design precise things.
With that said, one needs to recognize the "advanced fillet" moi fails at, and the "fillet at all costs" solutions.
8509.27 In reply to 8509.25
Hi klaudio, well I agree with everything you said, but unfortunately filleting is a particularly difficult area to improve. Right now the plan that I have to improve it involves using a library from another company and they aren't ready yet so it's not likely to happen for v4. If they take too long then I'll have to re-evaluate that plan but right now that seems to be the best way to make major progress for the longer term.
During the v4 beta process I will do a little experimentation to see if I can do a few tune-ups to the existing filleter but it's not too likely to give a really big improvement and it's pretty easy that altering how it works to improve one particular case will have side effects that will make things worse for other cases.
So improving fillets is definitely something that I want to do, but right now I'm waiting on some other people's work.
8509.28 In reply to 8509.26
Hi Burrman.
@You : "With that said, one needs to recognize the "advanced fillet" moi fails at, and the "fillet at all costs" solutions."
Well said!
8509.29
"What i mean by that is that Moi3D is aimed mostly for artists and "concept modeling", fast and fun, but the thing is that you are losing quite a bit of that fun when you want, for example, fillet something (hah, that fillet again..lol) and it just can't do it in certain situation and fails as soon as things get a bit more complex."
8509.30 In reply to 8509.27
Your candor is not only refreshing but greatly appreciated and clear. You have a great product, I use it daily and it is one of my favorite 3D applications. I am looking forward to v4!!
8509.31 In reply to 8509.27
Thank you very much for more info and explanation. It makes sense and i understand so i guess little bit of patience and we we'll get there eventually. ;)
I am little bit curios about "...the plan...involves using a library from another company ".
Is there any info for what will that new library mean for Moi? What kind of a things we can more or less expect from it eventually?
No need for in depth review, just some basic points if it's ok to share, of course! Perhaps some link for eventually relevant info to Moi for further read or/and any other software using that library as rough example of what potentially Moi might also get in the future?
Thanks!
8509.32 In reply to 8509.31
The kernel was the subject of several posts a few months ago.
My internet searches were not very fruitful.
8509.33 In reply to 8509.32
Kubotek KCM
8509.34 In reply to 8509.31
Hi klaudio,
> expect from it eventually? <...>
Well, the main goals to start with would be better filleting and shelling. The main thing after that would be "local operation" support for faces which means being able to transform a face and have the surrounding geometry extend to meet the edited surface. Another thing I'd be hopeful for would be surface fitting for hole filling.
Well since it's new and not finished yet there isn't any other software that uses it yet except in limited ways. Their goal though is to have it be the kernel for Kubotek KeyCreator though.
Show messages:  1-2  3-22  23-34
