MOI to Inkscape to MOI
All  1  2-15
8504.2 In reply to 8504.1
Have you tried PDF format?
That works fine in PDF between Moi3D and the free Gravit Designer http://moi3d.com/forum/messages.php?webtag=MOI&msg=8495.1
Moi3D-->Curves, Surfaces, colors -->Gravit Designer
Gravit Designer --> Curves -->Moi3D
8504.3 In reply to 8504.2
Thank you Monsieur Pilou I´ll try ot that way !
This Spiro ?
Else seems Inskape PDF woks fine when you Import it inside Moi! :)
So I suppose you will have no problem with the Spiro plugin! ;)
8504.6 In reply to 8504.4
This Spiro, yes.
I have read a comment, that MOI Mastermind Michael had plans about
implementing Spiro into MOI (wow) but that it was not possible to get
it licensed, unfortunately.
8504.7 In reply to 8504.5
Nice illustration, Pilou !
Importing works great. but changing the shape of an imported curve smoothly
is not easy due to the hig point density - and reducing the point number with
rebuild will change the curve shape in parts with a small radius.
There is a Clothoid2ptSlider script here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5878.34
There are a few EulerSpiral scripts as well.
But rebuild should be done...
8504.9 In reply to 8504.8
Hi Brian, thats an awesome script and very useful for my purpose.
Thank you - great tip !
8504.10 In reply to 8504.9
Maybe I have overseen a function / scripts in MOI offering a similar functionality
as the "Power Stroke" in Inkscape - if there is some I´ll be glad to hear from.
http://i.stack.imgur.com/yosPZ.png
http://wiki.inkscape.org/wiki/index.php/PowerStroke
https://www.youtube.com/watch?v=02RrZpty6AM
8504.11 In reply to 8504.10
Very smart!
In Moi you can make that...sure that is not calligraphy here...but if you have cool curves at the beginning...
(even here with 7 points you can make infinity of result and as you can add points...:)
and with no intimidating UI! ;)
some lines...can be a cool challenge with only 7 points!
Take also a look to this from Max Smirnov! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=7594.31
EDITED: 5 Jul 2017 by PILOU
8504.12 In reply to 8504.11
Pilou have you tried the Power Stroke in Inkscape ? As with Spiro it makes it
very easy to achieve long smooth changes in a curve with just a couple of points
and a great option of closing the ends with rounded caps.
Fat line is great but you cant achive changes in width as easily and smoothly as
with Power Stroke. But I am ging through all possibilities in MOI as I would
prefer to stay within MOI than to move between INK and MOI.
Big thanks to your contributiona by the way !
8504.13 In reply to 8504.12
No sorry on my old days Inskape is a too complex program for me!
I use it only as a go between programs for transfert and files formats!
8504.14 In reply to 8504.13
So you are missing the delight of working with the miraculous Spiro Curves ;-)
8504.15 In reply to 8504.14
Sure but i have only one life and the free Verve is enough sufficient for more infinite moving voluptuous delight! ;)
http://moi3d.com/forum/messages.php?webtag=MOI&msg=6589.1
Show messages: All  1  2-15
