Object Library help
All  1  2-4
8387.2 In reply to 8387.1
Hi Momo, so by default the object library stores its objects in a sub-folder inside MoI's main installation folder.
But also by default, as a security measure Windows prevents programs from modifying the contents of anything under Program Files. So probably that's what's happening to you.
Try running MoI with elevated privileges, to do that go to the shortcut you use to launch MoI and right-click it and choose "Properties". Then in there under the "Compatibility" section set the option for "Run this program as an administrator". Then when you launch it again it should hopefully work.
8387.3 In reply to 8387.2
AWESOME! yep. that was the case.
thank you!
8387.4 In reply to 8387.1
upload to your YouTube account and set them as UNLISTED. That way you can post the URL and folks can see it, but they won't see it on your YouTube stream.
Show messages: All  1  2-4
