Selection without adding
All  1  2-7
8297.2 In reply to 8297.1
8297.3 In reply to 8297.2
Thanks Pilou, that solved the push/pull problem. I must have misread that it was part of the extrude function, not just the translate.
8297.4 In reply to 8297.1
Hi Brendan, sorry no there isn't currently any way to turn off the automatic multiple selection, to make things work smoothly you just click in empty space to clear the selection when needed, or push the escape key. The reason why it's set up this way is because MoI was originally designed to work without needing to touch the keyboard continuously. I do think that in the future I will add an option for this but there isn't one currently.
About selection
It's direct selection!
So if you reclick on a selection that is the same than Click + Ctrl in another program! :)
So very more easy!
If you start to select an edge you can only select edges!
(curve, surface, volume etc)
8297.6 In reply to 8297.4
Thanks for getting back to me Michael,
I am definitely all for less repetitive movement when it comes to modeling. That said I find it currently causes more repetition because of the amount of object switching that needs to be done, especially in a boolean style workflow. I'm glad you can just hit escape to deselect because I find mouse clicking to be much more damaging when it comes to repetitive stress injuries. It just feels like it slows down the flow of modeling. The option to turn it on or off would be nice because it would accommodate multiple workflows.
On another note, I do like how re-clicking a selected object allows you to go in and pick elements of your choosing, no need to switch btw faces and edges.
On a whole tho, MoI has rekindled my modeling fire. It's so freeing compared to poly-modeling, and now that I've got my hotkeys set up it has that grand piano feel that XSI gives which makes things fast and unimpeded.
8297.7 In reply to 8297.6
Hi Gibbon, I just wanted to mention that there are some tips here for people coming from a poly modeling background that may be useful:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4865.2
The big difference with NURBS modeling is that booleans and cutting operations are the primary way to do things, not something you have to avoid like in sub-d modeling. Usually many of the final 3D edges in your model should be produced as the result of a boolean from a 2D profile curve, rather than positioning all final edges in 3D space as you would with sub-d modeling. So along these lines often it's best to build a simplified extended piece of "stock" material that then gets cut up, I think there are some examples of that in the above tips.
Show messages: All  1  2-7
