Tyre Tutorial - Flow problems
All  1-12  13-19
8273.13 In reply to 8273.10
Hi Sandeep, sorry I wasn't able to give you better information the first try, so what you've run into here is the control point spacing of your curve affecting the flow.
If you draw a control point curve and have some control points close together and others far apart from each other, it will make the "parameterization" of the curve also be similarly bunched together and stretched out, and for a surfacing command that preserves the exact structure of the curve into the surface it will mean the UV parameterization of the surface will be the same.
If you rebuild the curve before doing the revolve, it solves it because the rebuilt curve has much more even parameterization.
8273.14 In reply to 8273.13
Hello Michael,
thanks for the deeper explanation.
I will repeat the process a few times, so i get a better understanding all of this.
I am still curious about how Chipp managed to do it in his video, without re-building...?
Any thoughts?
Cheers.
Sandeep.
8273.15 In reply to 8273.14
part 1 : minute 5.25 - 5.40
he made the extrude line surface here from the original surface and no need the rebuild it!
EDITED: 23 Jan 2017 by PILOU
8273.16 In reply to 8273.15
Thank you PILOU. I doubled checked the video.
You are right, but when i rebuild the curve and revolve, it seems to
resolve the issue i was having. Especially since the tyre is now a surface.
I will do this tutorial again and let's see if it works without REBUILDING.
Speak soon.
Cheers.
Sandeep.
8273.17
Hello everyone! I finally did it! Lot's and lot's of learnings on this one.
Thank you for your help!
Sandeep.
8273.18
Coming a bit late to this thread, but I'm glad you're able to complete the tire, Sandeep. Your render looks FABULOUS!
8273.19 In reply to 8273.18
Hello Chipp!
Thank you for your response, i tried to reach out to you via your YouTube channel too.
Thanks for the great tutorial!
Cheers.
Sandeep.
Show messages: All  1-12  13-19
