Suggestions for Modeling special laundry basket
All  1-4  5-8
8227.5 In reply to 8227.1
Hi ActiveRendering, it tends to be a lot easier to make a repeating pattern like that all flat on the ground at first and then use Flow when you're done to warp it onto a curved surface as opposed to drawing the interwoven strands directly in place.
To make the pattern, something like this, start by drawing a control point curve with grid snap turned on placing points in a straight line and then move the ends downwards like this:
Then use Construct > Extrude to extrude the curve into a wide surface, then select the widened surface and run Extrude again to give it thickness:
Make a 90 degree rotated copy of it, quick way is to hold down ctrl and drag on the edit frame rotation handle:
Move the rotated piece over:
Copy this over diagonally one cell step to make the base pattern:
Then use Transform > Array > Grid to replicate the pattern, having used grid snap earlier can make it easier to figure out the array cell size you need.
Then you'll put a large plane under that which will be the base surface for Flow, then you'll have a curved vertical surface as the target for the Flow. There are some examples of Flow here: http://moi3d.com/3.0/docs/moi_command_reference8.htm#flow
I've attached 3DM file with an example starting cell, it's ready to be arrayed with a grid size of 15x15 to make the pattern.
8227.6
On a tangent: that would be really hard to injection mould as is. You'd need slides for the weave pattern but these would interfere the deep rim...
Sebastian
Message 8227.7 deleted 22 Dec 2016 by BEMFARMER
Google searches were mostly non-productive, but many other interesting topics were discovered!
After more pondering, it becomes clear that weaving strips would mechanically behave as elastica curves.
The _Elastica2 script, with a mu or U.value of around 0.95 to 0.98 seems very promising.
EDITED: 24 Dec 2016 by BEMFARMER
Show messages: All  1-4  5-8
