Tiny fillets on inset detail
All  1-7  8-14
8049.8 In reply to 8049.6
Hi Branden, no problem I'm glad that looks like it should work for you.
> Two things I learned here: the fillet command has a better success rate with on a
> portion of the surface if it's separated from the rest of a detailed solid/surface.
It's probably not going to always be a better success rate, but if I remember right what happens is if the object started out as a solid and after the fillet it isn't a solid anymore, it tries to do it again with a tightened up tolerance in the hope that will help getting pieces to align with each other better. But in this particular case here it ends up being worse when that happens.
> The only question I have is this: is the network tool in this case attempting to create a tangent
> blend with the surrounding surface? My guess is it's not.
No, it's not doing any special work to guarantee that it's tangent but with all the edges being tangent it's going to be extremely close.
8049.9
Michael, thanks for that explanation!
Cheers,
Branden
8049.10 In reply to 8049.7
OSTexo, Looks great to me. I'd love to hear how your approach differs from the one Michael detailed.
Cheers,
Branden
8049.11
Hello,
Sorry for the delay, here is the video:
https://vimeo.com/179994341
Enlighting!
8049.13 In reply to 8049.12
Clever technique!
Mik
8049.14
Thanks for sharing! Very nice. I liked the one about chamfers as well!
Show messages: All  1-7  8-14
