Morphostemic Anti-Gear …
 1-4  5-24  25-44  45-64  65
8030.25
Colleagues,
Another.
R
T
8030.26
8030.27
@> Nicolinux -- Keyshot.
8030.28
Ty,
Really nice work. Especially the attention to edge boundary details.
A couple fun things you might try:
Consider positioning your product on a rough metal grate (with hex holes in it) and a box below the grate which you can use in KeyShot as an area light. Use radioactive green. Set a RIM light of red or blue for contrast
1) Create a long lens (less perspective) shot with the horizon close to the ground. The bottom of the device (because of the coarse texture on the body) will reflect the green nicely.
2) Create a short lens with DOF birdseye (raking perspective) The green may dominate, but you may be able to use metal reflections to add other color to the shot via the RIM.
3) Use curvature and AO in KeyShot to create a weathered material so that it looks beat up -- you may want to see my MoI -> 3DCoat -> KeyShot tute on how to quickly apply proper UV coordinates to the OBJ before importing into KeyShot.
Just some ideas to toss around. Thanks for sharing!
8030.29
Chip,
All your ideas are really great -- thank you for taking time to send them along -- greatly appreciated.
With regards to the grid with the lights underneath -- is there an example you can point me to? Would love to get a better sense of what you're suggesting.
Thanks -- !
Rage on,
Ty
8030.30 In reply to 8030.29
I don't have time currently to experiment, but I did find a few 'inspiration' images which might help...
You can create smoke in KeyShot with alpha plains with Photoshop cloud textures in the transparency channels. Layer a bunch of them every which way.
Best of luck!
8030.31 In reply to 8030.30
Chip,
Thank you -- ! -- Will give it a try in the not too distant.
R
T
8030.32
Colleagues,
Managed to carve out a little bit of free time over the winter break to get a bit more MOI practice in.
Best wishes to everyone for a grand and evolutionary 2017.
Rage on,
Ty
8030.33 In reply to 8030.32
Hy TyRuben.
Thanks a lot for sharing an best wishes to you too!
Just one question...
These objects that your are modelling are only fantasy objects or something real ?
See you.
8030.34 In reply to 8030.32
Super slick Ty !
Thanks for sharing.
8030.35
@> mkdm -- Imaginary — in each, there's usually half a dozen “things” i’m trying to accomplish from a modeling or rendering perspective — so they are primarily driven by learning — however, I try and make them interesting as well.
@> PaQ — Thank you — !
Technologic! :)
8030.37
Pilou -- thank you -- !
8030.38
Ty.
Sweet. Very.
You should check out 3D Coat for some other ways of accomplishing 'sketching' in 3D. I've a tute or two up on YouTube. FWIW, 3D Coat also works great as a UV mapping tool for MoI3D (forget the topology unless you just want to play around). Works great and you can work directly with PBR and send to KeyShot.
8030.39
Chipp,
I've been looking into 3D Coat -- and very close to diving in -- my only worry is that renders often look kind of doughy -- but I've been told the speed of the workflow compensates for this -- will check out the videos -- thank you.
TyRuben
8030.40
Colleagues,
Finally found time to finish this one.
R
T
Technologic!
8030.42
OMG! I must have missed this thread... Impressive stuff! Great design and cool renderings!
8030.43 In reply to 8030.1
Very nice work Ty.
Inspirational and well done!
8030.44
Hi Ty,
Yes, you are correct, there is the 'doughy' thing. If you check out my video on 3D Coat Live Clay you'll see a way to work around some of that:
https://youtu.be/I9qMtMhrRbs
Show messages:  1-4  5-24  25-44  45-64  65
