Flow Letters Around Wedding Band
All  1  2-16
7980.2 In reply to 7980.1
Hello Philip,
the result depends on were you select the base and target surface. The selection point defines the u-v orientation of the flow. Try this points shown in the picture:-)
I hope that helps you a bit.
Have a nice day
Karsten
EDITED: 18 Dec 2017 by KMRQUS
7980.3 In reply to 7980.2
Thank you for your help - all sorted. Seems to be a case of trial and error. Is there a way to 'see' the UV direction like in Rhino?
Regards,
Philip
7980.4 In reply to 7980.3
Hello Philip,
it is not necessary to see the orientation. Click near the edge on the base surface that you want to use as your orientation. Do the same for the target surface. The side from which you pick, leads also to different results. Look at the picture under these infos and you will get it;-)
Have a nice day
Karsten
7980.5 In reply to 7980.3
Hi Philip, also you should check out the help file where the picking process is describe in detail: http://moi3d.com/3.0/docs/moi_command_reference8.htm#flow
You don't have to do it by trial and error, you control it by clicking on specific areas on each surface and then it will match up those pick locations. You want to click close to an edge, on one side of the edge as described and illustrated in the help file.
7980.6
Hi
Try this , here is a flow that has history turned on and you can move the text etc after the flow and it will update the results
This makes it a lot easier than trying it 20 times to get everything in the right place
cheers
shayne
7980.7 In reply to 7980.6
Hi shayno,
Thank you very much for this modified version of the flow command.
A very little difference, compared to the original, that gives a big benefit!
factory.getCreatedObjects().setProperty( 'updateWithHistory', true );
Ciao!
Marco (mkdm).
7980.8
HI Michael
Can the history update be written into to the array curve command ?
it would make a huge difference to my work
wishlist for V4 perhaps
Kind Regards
shayne
7980.9 In reply to 7980.8
Hi shayne, no unfortunately it's not possible currently to get history update working on array commands. History is not stored for those particular commands because it was causing large bloated file sizes to store all inputs for the array on each generated instance.
In the future I do expect to change the history function to work more like a log of actions rather than being attached to each object. But there will be a lot of work involved in doing that so I'm not sure when it will happen.
7980.10 In reply to 7980.9
From the point of view of a software developer, i must admit that i really appreciate your way
to elegantly disenchant the users' wishes.
Ciao!
Marco (mkdm).
7980.11 In reply to 7980.10
Thanks Marco! :)
7980.12
Thanks Michael
I regret some things in life are not possible :( but one can but dream :)
I use Moi everyday to manufacture jewellery and its brilliant
Thank you and the forum for all your help over the years
shayne
EDITED: 8 Jun 2016 by SHAYNO
True gem! ;)
7980.14 In reply to 7980.12
Hi shayne, your ring is lovely!
7980.15 In reply to 7980.14
Thanks Michael
my saveas.js has the following to save a jpg with the save
can this be changed to just save the 3d view only
thanks
shayne
// config: norepeat
moi.geometryDatabase.saveAs( moi.command.getCommandLineParams() );
script:var img = moi.view.screenshot( 'viewpanel', false ); var filename = moi.geometryDatabase.currentFileName; if ( filename != '' ) { img.save( filename.substring(0,filename.length-3) + 'jpg' ); }
7980.16 In reply to 7980.15
Hi shayne,
Try changing your current parameter 'viewpanel' to instead be '3D' . Then if you're in split view mode it should target the 3D view. If you're in a maximized view mode it will behave the same as 'viewpanel' though.
Show messages: All  1  2-16
