Modeling question
All  1-3  4-5
7831.4 In reply to 7831.1
Hi Pieters, yes like Martin writes Construct > Loft would be the tool for that.
You'd want to draw a circle and a triangle, drag the circle upwards in the Z direction, then select both of them and run Construct > Loft to build the shape. Let me know if you are stuck with this process and I will make an example video for you.
It may be a good idea to browse through the reference section of the help file, especially the Construct section:
http://moi3d.com/3.0/docs/moi_command_reference7.htm#Construct
There are are a lot of images in there that show what each command can do - the one for Loft for example has these example images which are similar to what you're doing:
7831.5 In reply to 7831.4
Thank you so much, Mr Gibson. Your Mac- and Windows (!) - application turns out to be a God-send for me and I got a bit all worked up about nothing as you can tell. This is actually my very first 3D-project as an established artist and I'm gonna have it printed soon.
Take it easy with v4, you don't have too many NURBS competitors out there anyway and I'm sure to read more of your well illustrated manual later.
Bye
EDITED: 31 Jan 2016 by BAFZER
Show messages: All  1-3  4-5
