Boolean Problem
All  1-3  4-6
7757.4 In reply to 7757.3
""""""""EDIT: Burr is beating me to the punch these days!""""""
Except you explained what the "errant surfaces" are and are from...
Probably drinking our coffee's at the same time. :)
7757.5
Thanks guys! Yes, it was created with FLOW. Good tip on leaving off the end caps. Wondering, with flow and a circular object, will it alway align properly, assuming the base and target files are set up correctly?
7757.6 In reply to 7757.5
Hi Chipp,
Yes, it ought to if everything is set up to match. I think it may not automatically join the open ends to each other though, that may require an extra separate/rejoin step if that's the case.
Show messages: All  1-3  4-6
