Blend command
All  1-5  6-10
7749.6 In reply to 7749.5
Hi Micheal.
I'm playing the Blend command and got the same issue.
I did double check. There is no curves selected.
When I try to blend the edges there's always a 'calculation failed' message.
You can find a screenshot here:
https://drive.google.com/open?id=1GsUcRBW3-gkzWyCQ5AwgvcdAKdSa5igc
Do you have any idea on how to fix that?
Thank you very much
Roger Macedo
7749.7 In reply to 7749.6
Hi Roger, can you please post the 3DM model file for that so I can try the blend over here?
7749.8 In reply to 7749.7
Thank you for the prompt response, Michael.
Please, find the file here:
https://drive.google.com/open?id=1ON1IvNqrYSTmbFlTndDsSWOZo_VdH0JQ
Best regards,
Roger
Roger Macedo
7749.9 In reply to 7749.8
Hi Roger, that's happening because Blend sees edges that touch each other as part of one long chain for one side of the blend, so in this kind of arrangement it is only getting one long thing instead of 2 sides. However, if you give it only 2 edges it will take each one as one side even if they touch.
In this attached version I've used the Merge command (http://moi3d.com/3.0/docs/moi_command_reference10.htm#merge) on your edges so there is just one edge on each side and now that should work.
I do want to improve the Blend command in the future so that your original case would work though.
7749.10 In reply to 7749.9
Thank you very much for clarifying, Michael. I did some tests merging the edges and worked nicely :-)
Have a great weekend!
Roger
Roger Macedo
Show messages: All  1-5  6-10
