Using PatterNodes to Create a Speaker Grill Detail
 1-2  3-22  23-42  43-58
Hi everyone,
My name is Marco and although i play sometimes with this very cool piece of software (Moi),
in the demo version, just to test some graphics ideas, i'm a newbie in this forum,
and i wish to thank everyone for all the posts relate to this software,
'cause you have really urged my fantasy.
I'm observing that a old, and ever new, technical theme is affecting more and more users
of Moi.
The algorithmic modeling pattern.
Chippwalters, i made some search and i've found this other really interesting free tool
for generative design pattern, also available for windows plataform.
NodeBox 3
https://www.nodebox.net/
I've made a quick test and i verified that is possible to export the generated graphic in pdf format,
readable from Moi.
Last, but not least, thank you very much Max Smirnov, for you cool work on Nodeeditor !!
Good day to everyone,
Marco.
Sure Marco!
Terrific indeed! Just 2 nodes infinities of results!
After extrusion :)
EDITED: 3 Dec 2015 by PILOU
7745.5
I wrote a script inspired by this tutorial :)
Thank you Chipp!
EDITED: 7 Mar 2022 by SMIRNOV
7745.7 In reply to 7745.5
Hi Max,
Actually, I thought you might get inspired looking at that node editor and think of new things to add to yours! Thanks for the script!!
7745.8
Moi is so awesome man...here I am...needing to add vent holes to a model, wondering how others may have done it...and Bam! Max writes a script for it!
Thanks all.
7745.9
Great stuff -- thank you for sharing.
7745.10
RadialPattern v.1.2
Added:
- custom shapes support (select any object before the script run)
- click on title to randomize values
7745.11 In reply to 7745.10
SWEET! I was thinking about asking you for custom shapes. SUPER!!!!
Thanks Max :-)
7745.12 In reply to 7745.10
If you select nothing, the first time at the lauch of MOi there an alert message!
Cool even volumes! :)
French Version
http://moiscript.weebly.com/scripts-de-max-smirnov.html
EDITED: 5 Dec 2015 by PILOU
7745.14
Use of Max's new RadialPattern script:
EDITED: 6 Dec 2015 by CHIPPWALTERS
Rolling wheels! :)
7745.16
Excellent script, as usual.
Thanks a lot MAX.
Mik
7745.17
bugfix update
v.1.3
7745.18 In reply to 7745.17
7745.19
Max Smirnov,
Thank you for the free use of your many scripts, especially the RadialPattern script!
I salute your generosity and hope that good fortunes will soon offer me an enhanced capacity to reciprocate.
Regards,
-- Mindset
EDITED: 26 Jan 2017 by IGNITER
Flashy!
7745.21
In search for a solution for a pattern design I came across this great script.
My question is : I need equidistant gaps between the multiplied objects -
is this achievable wit this script ?
Or achievable by other means ?
Best TOM
7745.22 In reply to 7745.21
I don't know what is the nature of your object result but if you press Tab then write ExplodeMove (without space) maybe you will have your result wanted! ;)
Explode Move is hidden function but integrated inside the Native Moi3D !
Else you can recreate all the plugin PatterNodes or what anything you want exactly with ELEPHANT! ;)
http://moiscript.weebly.com/biblio-elephant.html
EDITED: 27 Sep 2019 by PILOU
Show messages:  1-2  3-22  23-42  43-58
