MOI and Simlab Composer
All  1-9  10-13
7719.10 In reply to 7719.9
Hi BurrMan & Chris, if you import MoI 3DM files, the NURBs are imported directly. You will need to tell KS5 & 6 to render NURBs data. As far as i know all other NURBs formats have the option to tessellate upon import. Simple rule of thumb, if you try to import a file and KS reports a no geometry found error, the check the import NURBs data option and you should be good to go.
Martin
(TpwUK)
For KeyShot, the "Import NURBS" option mentioned above is under the Geometry section of the Import options dialog, it's shown around 30 seconds in on the video Pilou links to above. Here's a link to a bit larger displayed version of the video:
https://www.youtube.com/watch?v=iZmrTkC-8ac
7719.12
I mostly export OBJ to KeyShot. They render much faster and importantly, if exported from MoI correctly, allow for small fillets to be added to the geometry at render time, creating even more realistic renders.
Just my 2 cents.
7719.13 In reply to 7719.12
I just requested the render time filleting for SimLab a few days ago ... hopefully will make into the development cycle.
Show messages: All  1-9  10-13
