Export bug?
All  1-5  6-16
7696.6 In reply to 7696.4
Hi Chipp, so it looks like there are 4 problematic surfaces - these 2 on each side:
If you delete those 4 surfaces your export will then go ok. If you construct something new to fill in those 4 open areas then you should be ok after that.
Those 4 surfaces just happen to be mangled in a way that the export mesher really doesn't like too much. I think if you let it sit for a really long time it might finish eventually though.
Hope this helps,
7696.7 In reply to 7696.6
And you may need to divide up those open areas in half or something like that to fill them in very well rather than trying to do a sweep or something along a sharply hooked shaped boundary like that which would tend to make a surface that folded back over top of itself.
7696.8
Michael,
Please don't spend any time on my behalf resolving these details. It was just something I was playing around with.
I ended up taking the previous .obj import (from Max's script as I mentioned earlier), and exported as STEP then placed into Onshape and performed what fillets I could there. Then imported back into MoI and added the kitbash items there, along with a calculated fillet (the one where you sweep a circle along a path, bool diff it from the model and stitch it back up with Blend and Network).
The places you point to are obvious errors introduced in Onshape or when exported as STEP from Onshape.
Good to know. Thanks for your help. :-)
7696.9 In reply to 7696.6
The 2 lower ones can be filled in with planar surfaces, after you delete each one, select the main object and run Construct > Planar to fill in the hole. Do those one by one so you don't open up a larger non-planar hole as would happen if you deleted both of them at once.
Then the upper one runs into some problem trying to do that I think because of a teeny tiny edge in this area here:
That little edge is only 0.0004 units long and something around that size under the fitting tolerance tends to get collapsed down and cause topology problems.
That may need to be dealt with by drawing in a line from its end and making a triangle on the left side there first, then the remaining area will probably behave better. Let me know if you're stuck with that part.
7696.10 In reply to 7696.8
FYI, yes, I left it long enough and eventually it *DID* export. :-D
@Chipp
<< The places you point to are obvious errors introduced in Onshape or when exported as STEP from Onshape.
Yon know that you can now also use again 123D Design between Moi for delicate fillets ! ;)
http://www.123dapp.com/design
Because Step / Sat format import export have made their return for Free version! ;)
DIfference than Onshape : it's a local application! ;)
7696.12 In reply to 7696.11
Thanks Frenchy, DID not know that. Much appreciated!
7696.13
FWIW, I really like the Autodesk 123D program. I don't see where it exports STEP, but SAT works fine. I was able to quickly cobble together a basic widget in short order:
Create the basic shape in MoI
Export as SAT to 123D, fillet there using dynamic filleting, and bring back as imported SAT. Next add some kitbash:
Exports as OBJ to KeyShot and VoilĂ
7696.14 In reply to 7696.13
@Chipp
<<I don't see where it exports STEP, but SAT works fine.
Don't know what format is the best for you? :)
But your results seems yet convincing!
PS Free version is of course for no commercial use! ;)
When you press it you have that! :) (Windows user)
EDITED: 1 Nov 2015 by PILOU
7696.15 In reply to 7696.14
Interesting. Mine is different (I'm using free commercial version downloaded from Mac App Store)
7696.16 In reply to 7696.15
@Chipp
Maybe an "advantage" or more "disadvantage"of the Mac World! ;)
In any case one format is yet sufficient for Nurbs world! :)
Show messages: All  1-5  6-16
