My MoI3D Workflow Shortcuts
All  1-2  3-14
Cool showcase of possibilities of Moi customize use!
Shortcuts are good for training memory! :)
7695.4
Excellent video Chip. Thank you very much for INI file (I also set my shortcuts close to LW settings ;)).
Is there way to get same GUI look as yours ? I've made mine very close but i cant' get rid of that middle line between view-ports to go darker/change color.
Lewis
www.lewis.tomsoft.hr
www.ram-studio.hr
Skype - lewis3d
7695.5 In reply to 7695.4
Hi Lewis,
Here's a link to the post which has the image you are looking for:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7245.3
7695.6 In reply to 7695.5
Ex lw, current modo user here ... and as a result my shortcut key list is nearly the same as yours chip ! :)
... but you have some really clever script I need to steal, so thanks for sharing !
7695.7 In reply to 7695.6
You're most welcome :-) Glad they could be of service.
7695.8
YES, that was it, thanks Chip :).
Lewis
www.ram-studio.hr
Skype - lewis3d
7695.9 In reply to 7695.1
Thanks for the video Chipp. I've subscribed to your Youtube channel too - although watching your videos made me say WTF!? even more often than I say it while coding :)
But that's due to my noobness and will change over time.
I have one question though. How did you get the nice effect on your selected objects (not the shading style you selected at the bottom at some point) but the "default" one with the highlight on some faces.
7695.10
7695.11 In reply to 7695.1
thank you ,chippwalters,I have a big problem,when I install your moi.ini file ,I open moi3d,the shortcuts are working ,but the shift +F6 and shitf + P has bug that make my screen white ,what’s more,when I try to create a box or curve,their edges become too thick?how to fix this?I uninstalled the moi3d,reinstall moi3d,and restart my PC,but the problem still happen. Hope you can help me .
yytssln
7695.12 In reply to 7695.11
Hi yytssln,
I am not sure what the nature of the problem is, but I just wanted to point out that moi has changed a bit during the last 5 years, so that could maybe create issues with an old moi.ini.
Chipp is awesome btw :)
7695.13 In reply to 7695.12
thanks ,I know how to fix this,just go to the option----veiw,click the restore defaults button,choose the current section only,ok.
7695.14 In reply to 7695.11
Hi yytssln, it looks like both Shift+F6 and Shift+P are duplicates of each other there.
I tested the script over here and it seems to be working ok for me.
I suspect that maybe your video card does not support rendering to that high of a resolution image and so the viewport .render() method is throwing an exception which the script is not expecting. When that happens the cleanup step (where the script restores viewport properties that it modified before making the screenshot image) does not happen.
Try putting in this updated version:
script: /* Save to PNG */ var vp = moi.ui.getLastClickedViewport(); if (!vp) { vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); } var filename = moi.filesystem.GetSaveFileName( 'Save', ' (*.png)|*.png' ); var st = [], settings = ["view.viewportBackgroundColor", "view.lineWidth", "grid.display", "grid.showXYAxes", "view.showAxisIcon", "view.meshAngle"]; for (var sv in settings) { st.push(moi[settings[sv].split('.')[0]][settings[sv].split('.')[1]] ); } moi.view.viewportBackgroundColor = 0xFFFFFF; moi.view.lineWidth = 3; moi.grid.display = false; moi.grid.showXYAxes = false; moi.view.showAxisIcon = false; moi.view.meshAngle = 3; try { vp.render( 4000, 2500 ).save(filename); } catch(e){} for (var sv in settings) { moi[settings[sv].split('.')[0]][settings[sv].split('.')[1]] = st.shift(); }
I think this version should now tolerate the viewport .render() method possibly failing.
But probably to get an image actually generated you'll have to modify the vp.render( 4000, 2500 ) to a lower resolution than 4000x2500, for your particular video card's limits.
Show messages: All  1-2  3-14
