Any chance to fix this?
All  1-6  7-15
7693.7 In reply to 7693.5
The edge is present at the other side as well.
7693.8 In reply to 7693.6
Hi Sven,
> Unfortunately I already deleted the greeble which I have substracted. Mistake...
Well the base pieces can be recovered to some extent by separating things into individual surfaces and then doing an "untrim". Untrim is described here: http://moi3d.com/forum/index.php?webtag=MOI&msg=444.4
I'll see if I can make a larger surface from the revolved part.
7693.9 In reply to 7693.8
I"ll have to try it a bit later today though.
Basically the process is to extract the rounded piece using Edit > Separate, untrim it, then extract its seam edge, draw a line to extend that curve, join them together, use Rebuild to fuse it into one single longer curve segment, then revolve that to get a larger revolve surface.
7693.10
I have "wrong" edges on the other cuts as well. Next time, I will take care of this problem. Lesson learned ;-)
7693.11 In reply to 7693.5
>>> Michael wrote "...making up that one testicle and..."
You're just not right ... :)
by the way, I don't think he wants to use the 'trim' command. It would be called the 'circumscribe' command in this case. I think Max should make a script.
OK, I'll stop with the potty humor..
DS
7693.12
Here's how I would fix this:
7693.13 In reply to 7693.12
That's awesome! Thank you so much for your effort!!!
Know what? I saw the beginning of the youtube video before your posting was visible on the forum. Then I switched back to the forum and saw your posting :-)
7693.14 In reply to 7693.12
Thanks Chipp, that's a good solution! And less painful without trimming any delicate areas too... :)
7693.15
And I thought this was a forum I could safely read while drinking my morning coffee. How does caffeine affect the anti-reflection coating on Apple displays? Anyone?
Show messages: All  1-6  7-15
