Thicken outer surface
All  1-2  3-8
7653.3
Hello,
The top edge is racked a bit by .0085mm, that is probably why you are unable to get this to work.
7653.4 In reply to 7653.3
What do you mean with "racked"? If you mean the irregularities - then this must be a rendering issue. The outer edge should be straight/smooth.
7653.5 In reply to 7653.1
Hi Stefan - when you do Shell with a face selected, MoI will try to thicken all the other faces in the object but leave the selected one to be not offset so that it forms a opening there. See here for some examples:
http://moi3d.com/3.0/docs/moi_command_reference7.htm#shell
It sounds like you do not want that particular kind of thickening - if you want to thicken the outer wall you could select it and then run Construct > Offset to build an offset surface from the original, then delete the original outer face and use Construct> Planar to fill in the open areas.
There seems to be some difficulty with a couple of edges there though which is making building planar surfaces problematic, I'll take a look and try to see what is wrong.
7653.6
Hello Nicolinux,
Some of your surfaces aren't planar so it will be difficult to Shell. I have attached a file where I just created the construction curves and used Boolean and Fillet. All that needs to be done to thicken the outside dimension is to determine how much of a wall thickness you would like and draw the offset curve and Extrude. Hope this helps.
7653.7 In reply to 7653.4
Hi Stefan, are you set up ok now with the file OSTexo posted above? Or do you still need more help?
Please let me know if you are still stuck.
7653.8
Thanks for the help guys,
I think I am fine after I am able to understand what OSTexo did :)
Sorry for beeing such a noob...
Show messages: All  1-2  3-8
