Vojtisek's weapon grip Tutorial
All  1-6  7-13
7636.7 In reply to 7636.6
Bonjour Monsieur Pilou,
Sometimes we need some extra sandpaper to 'round the edges'! For that, IMO, Onshape is the best. In fact I can't even get Fusion 360 to open a MoI SAT or STP file. It just crashes. And Viacad's workflow actually makes my fingers hurt.
Yes, I typically like to record first, then annotate. That way I can speed things up so it's not too boring. Usually I build it w/out recording first, then clear, then start recording. This time I just turned on Camtasia and started making the model. It was quite long, and I deleted a section where I couldn't get Onshape to fillet correctly (I was using too large a dimension by a factor of 10). And then I sped it up 800X, the most I believe I've ever sped up a tute.
Je ne comprend pas "There is no system of "Show simplified Commands" in the left Bottom Corner?"
7636.8 In reply to 7636.7
@ Chipp: Thx for the infos!
<< "There is no system of "Show simplified Commands" in the left Bottom Corner?"
Something like this! ;) It's more confortable (if possible) than look at the normal Moi menu up/ middle right side! ;)
Start at 0.12 minute - but Idon't know if this is existing for Moi!
EDITED: 26 Sep 2015 by PILOU
7636.9 In reply to 7636.8
Thanks for the tut Chipp, always interesting to see how other people works !
Will give Onshape a try, wish one of this 'free' cad system will have a clipboard copy feature so you can quickly exchange geometry on the fly.
It's very impressive to see Onshape in even working on a phone/tablet Oo
7636.10 In reply to 7636.8
Thanks Frenchy.
I understand. I'll see if Camtasia allows for that feature-- it's a great idea!
7636.11 In reply to 7636.1
Great tutorial Chipp. The fast-forward pace was just right for me, as real-time tutorials can sometimes be like watching paint dry.
When I made my car tutorial a few months back I paid no attention to corner points when making cutting objects (never occurred to me they could be an issue). Maybe I was just lucky that fillets worked in some pretty complex areas, like the wheels for example.
It's a shame that MoI fillets are not more robust, but very interesting to see how Onshape completed your task. I really hate the idea of using two programs to accomplish something like that, but it's good to know a back-up method exists.
Hope to see more tutorials from you.
7636.12
Hi Chipp
Thanks for the tutorials I have learned a lot. Someone should do a tutorial on how to set up scripts. I know that Ed helped me install the subd ones that he used to make his car but I couldn't get the Voronoi script to work.
Keith
Yes Fillet inside OnShape is some confortable and robust! :)
And this one function inside Fusion 360 is not so bad also! ;)
Return in Onshape :)
http://simscale.com/pricing/ a 0$ pricing is existing!
EDITED: 27 Sep 2015 by PILOU
Show messages: All  1-6  7-13
