Fun with Booleans and Fillets
 1-8  9-22
7610.9 In reply to 7610.1
Second version with more booleans and fillets...
7610.10 In reply to 7610.9
Wonderful.
7610.11
Another test using my kitbash library..
7610.12 In reply to 7610.11
Very design!
Perfect for Alessi shop! :D
7610.13
Another form test. Vitaly Bulgarov has been using MoI3D to create some amazing sci-fi props, and I took inspiration from some of his work.
7610.14 In reply to 7610.13
A marvellous no-utilitarian object! :D
(What render ? )
7610.15 In reply to 7610.14
KeyShot. It's fast and works every time. :-)
7610.16 In reply to 7610.15
Hi Chipp,
Nice stuff. A quick question. When you modeled and setup these types of component cuts, etc, did you just do a straight cut and fillet the edges to give the "separation" effect? Or did you model some type of tolerance gap there, into the cuts also?
Thanks!
<< KeyShot. It's fast and works every time.
In your case
KeyShot "for direct Nurbs" or for files "OBJ" export ?
7610.18 In reply to 7610.16
Hey BurrMan,
I drew a single polyline, radiused it, then offset it the gapwidth with cap ends turned on. Then I just boolean diff'd it. If I wanted to create a 'trench' gap, I would've boolean merged it, then scaled it down on the z direction (height) then boolean unioned.
HTH,
C
7610.19 In reply to 7610.17
Hi Frenchy,
I use OBJ just in case I want to add some very tiny edge fillets. The nurbs works fine, but is slower and doesn't allow for rendered edge fillets.
7610.20 In reply to 7610.13
Very nice Chipp, I love that Bulgarov style of tech.
Moi is very strong in that and suprisingly stable, even after long times of calculations, when I'm expecting crash, it do the job :).
Vojtěch
https://vojtisek.artstation.com
7610.21 In reply to 7610.20
Yes, I agree Vojtěch, I'm amazed at how stable and powerful. I created this on a New MacBook, which is very underpowered. Took an hour of dinking around..
7610.22 In reply to 7610.21
We remark the reuse of the radiuses Tuto fillets form ! ;)
Show messages:  1-8  9-22
