Fun with Booleans and Fillets
 1-9  10-22
7610.10 In reply to 7610.9
Wonderful.
7610.11
Another test using my kitbash library..
7610.12 In reply to 7610.11
Very design!
Perfect for Alessi shop! :D
7610.13
Another form test. Vitaly Bulgarov has been using MoI3D to create some amazing sci-fi props, and I took inspiration from some of his work.
7610.14 In reply to 7610.13
A marvellous no-utilitarian object! :D
(What render ? )
7610.15 In reply to 7610.14
KeyShot. It's fast and works every time. :-)
7610.16 In reply to 7610.15
Hi Chipp,
Nice stuff. A quick question. When you modeled and setup these types of component cuts, etc, did you just do a straight cut and fillet the edges to give the "separation" effect? Or did you model some type of tolerance gap there, into the cuts also?
Thanks!
<< KeyShot. It's fast and works every time.
In your case
KeyShot "for direct Nurbs" or for files "OBJ" export ?
7610.18 In reply to 7610.16
Hey BurrMan,
I drew a single polyline, radiused it, then offset it the gapwidth with cap ends turned on. Then I just boolean diff'd it. If I wanted to create a 'trench' gap, I would've boolean merged it, then scaled it down on the z direction (height) then boolean unioned.
HTH,
C
7610.19 In reply to 7610.17
Hi Frenchy,
I use OBJ just in case I want to add some very tiny edge fillets. The nurbs works fine, but is slower and doesn't allow for rendered edge fillets.
7610.20 In reply to 7610.13
Very nice Chipp, I love that Bulgarov style of tech.
Moi is very strong in that and suprisingly stable, even after long times of calculations, when I'm expecting crash, it do the job :).
Vojtěch
https://vojtisek.artstation.com
7610.21 In reply to 7610.20
Yes, I agree Vojtěch, I'm amazed at how stable and powerful. I created this on a New MacBook, which is very underpowered. Took an hour of dinking around..
7610.22 In reply to 7610.21
We remark the reuse of the radiuses Tuto fillets form ! ;)
Show messages:  1-9  10-22
