A useful Kitbash technique for MoI3D
 1  2-21  22-41  42-50
7592.2 In reply to 7592.1
Fantastic tutorial! Big thank`s!
EDITED: 5 Sep 2015 by KRASS
7592.3 In reply to 7592.1
Great tutorial Chipp - thanks for sharing!
I've often wished MoI had a cloud based Object Library - in the same way users of render programs share materials.
Collections of common components could greatly speed the creation of concept drawings for example.
Possible object categories:
Electronic parts
Mechanical fasteners
CNC machine components
Robotic components
Very efficient!
@Chipp
Can I translate this page ? (and use the images on it)
https://altuit.cloud/web/dbpub/WidgetGadgets4Moi3D/WidgetIndexDONOTMOVE/wgIndex.html
All widgets on this page are free ?
EDITED: 5 Sep 2015 by PILOU
7592.5
Great tutorial! I'm happy that my scripts helps you :)
7592.6 In reply to 7592.4
Absolutely Frenchy. You're always welcome to translate anything you like from me. :-)
7592.7 In reply to 7592.5
Big Thanks Max for your wonderful scripts and help!
And thanks to others for the comments.
7592.8 In reply to 7592.3
Hi Ed,
By using Dropbox with a custom objects folders with Max's scripts, I effectively do hava a cloud-based object repository. If I were to share my folder with another user, they could then also have somewhere they could put their library objects and we would both see them.
At some point, I suspect the Object Library browser would need to have tabs or folders some other way of helping organize the many library objects.
7592.10
I updated the kitbash site this evening in an interesting way.
http://bit.ly/moikitbash
Most of you know I use Max's Obj Library scripts. He has a custom config in it which allows me to set the folder the library objects are stored to. So, I use a Dropbox Public folder, so I can pull images and files directly.
Then I created the data for the webpages as markdown and use MDwiki in a Dropbox folder to render the md to html. Now, anytime the md changes, the html is re-rendered on demand.
Finally, I wrote a small daemon on my local machine which monitors the Obj Lib folder and rebuilds the md file in Dropbox when things change. So, this means everytime I save a new Obj Library item, it is automatically available on the website. Check it out. Many more out there.
Max, if you're listening. Can you possibly suggest an easy way to 'page' through multiple libraries? For instance, would it be possible to have different folders to represent different libraries? I'm afraid I'll fill the current interface up pretty soon.
An interesting tweak to this process would be to create a Google Spreadsheet documenting all the scripts and plugins for MoI, and share it with the community. Then have a Daemon suck down the data at pre-recorded intervals (once per hour?) and render all the data to a Dropbox website, thus keeping all plugins, tutorials, etc. current and easily editable by specific community members.
Good idea???
7592.11 In reply to 7592.10
@Chipp
As you know i have made a French version here
http://moiscript.weebly.com/kitbash.html
I will not remake a so sophisticated one ;)
I wish that you have not change the adress's link of your objects! :)
(you have changed the adress of the original old page! ;)
But that will be usefull to have somewhere the historic of the "new objects" to avoid (for me) to run on the ancient list! Time consuming!
(maybe a number ? Colors ?...) or more simply a little list here of new objects ? :)
for this time seems the news are:
Moi3D Logo
Cross_Blivet
and Some v_blivet
surely miss someones!
Not yet added before know new infos of your part! :)
Here your old original page! :) (that i had adapted so the list that i have)
EDITED: 18 Oct 2015 by PILOU
7592.12 In reply to 7592.11
There have been many changes to the new objects, including updating old ones to work better. I would suggest you only translate the top part of the list and put a link to the English page as there's no need for translation for the Widgets. Just a name and a link for each. This way your list will always be the most current.
7592.13 In reply to 7592.10
Hi Chipp
Obj Library script supports multiple libraries. Just put the paths to config file "\ui\customui\mods\ObjLibrary.cfg.htm"
Example:
Library1;C:\...\Path1
Library2;C:\...\Path2
Library3;C:\...\Path3
also I wrote another version of this script. You can open it as dialog window.
copy ObjLibrary.dialog.htm to \ui\customui\mods\
Use this command to open a dialog window: moi.ui.createDialog( 'customui/mods/ObjLibrary.dialog.htm', 'resizeable' );
Yes, it's great idea.
But it will be better if Michael create an official online script repository and built-in script manager. Something like Notepad++ Plugin manager.
EDITED: 7 Mar 2022 by SMIRNOV
7592.14 In reply to 7592.12
<< Just a name and a link for each. This way your list will always be the most current.
There is a little description of each objects! ;)
Maybe you can send me just the names of the new entering objects!
Like this I can reconstruct easily the big list! ;)
I suppose that your files has a date of creation : so just sort by date and you will have the news object on the top! :)
7592.15 In reply to 7592.14
The whole point of the new 'scheme' is I can continue to build widgets and they will automatically be uploaded to the website as soon as I save them. There is no metadata for description, therefore I can't provide it.
My suggestion is to translate the top of the website in French, then provide a link to the top item on the page, which currently is:
https://altuit.cloud/web/dbpub/markdown/MoiObjLibDontMove/mdwiki.html#!index.md#BLIVET-SQUARE
That's about best I can do.
7592.16 In reply to 7592.15
And they are input in Alphabetic order so that is not my cup of thea! :D
..but better than nothing : I open 2 screens your and mine
Rool them and when there is a difference that the new one etc...
PS You have not updated your Kitbash link in your Moi's Signature! :)
EDITED: 19 Oct 2015 by PILOU
OK Updated! :)
PS your adress Links & Images are permanent ?
7592.18 In reply to 7592.16
It may be better I just share a library via Dropbox now that Max has multiple folder support.
I will think how best to accomplish this.
I did change my sig a couple days ago, but the new sig will only apply to new messages. Try the one below.
7592.19 In reply to 7592.17
Yes, they should be permanent.
Cool! :)
7592.21
Very very nice! :)
Arian DESIGN
www.arianshamil.com
Show messages:  1  2-21  22-41  42-50
