A useful Kitbash technique for MoI3D
 1-10  11-30  31-50
7592.11 In reply to 7592.10
@Chipp
As you know i have made a French version here
http://moiscript.weebly.com/kitbash.html
I will not remake a so sophisticated one ;)
I wish that you have not change the adress's link of your objects! :)
(you have changed the adress of the original old page! ;)
But that will be usefull to have somewhere the historic of the "new objects" to avoid (for me) to run on the ancient list! Time consuming!
(maybe a number ? Colors ?...) or more simply a little list here of new objects ? :)
for this time seems the news are:
Moi3D Logo
Cross_Blivet
and Some v_blivet
surely miss someones!
Not yet added before know new infos of your part! :)
Here your old original page! :) (that i had adapted so the list that i have)
https://altuit.cloud/web/dbpub/WidgetGadgets4Moi3D/WidgetIndexDONOTMOVE/wgIndex.html
EDITED: 18 Oct 2015 by PILOU
7592.12 In reply to 7592.11
There have been many changes to the new objects, including updating old ones to work better. I would suggest you only translate the top part of the list and put a link to the English page as there's no need for translation for the Widgets. Just a name and a link for each. This way your list will always be the most current.
7592.13 In reply to 7592.10
Hi Chipp
>> For instance, would it be possible to have different folders to represent different libraries?
Obj Library script supports multiple libraries. Just put the paths to config file "\ui\customui\mods\ObjLibrary.cfg.htm"
Example:
Library1;C:\...\Path1
Library2;C:\...\Path2
Library3;C:\...\Path3
also I wrote another version of this script. You can open it as dialog window.
copy ObjLibrary.dialog.htm to \ui\customui\mods\
Use this command to open a dialog window: moi.ui.createDialog( 'customui/mods/ObjLibrary.dialog.htm', 'resizeable' );
>> An interesting tweak to this process would be to create a Google Spreadsheet documenting all the scripts and plugins for MoI, and share it with the community.
Yes, it's great idea.
But it will be better if Michael create an official online script repository and built-in script manager. Something like Notepad++ Plugin manager.
EDITED: 7 Mar 2022 by SMIRNOV
7592.14 In reply to 7592.12
<< Just a name and a link for each. This way your list will always be the most current.
There is a little description of each objects! ;)
Maybe you can send me just the names of the new entering objects!
Like this I can reconstruct easily the big list! ;)
I suppose that your files has a date of creation : so just sort by date and you will have the news object on the top! :)
7592.15 In reply to 7592.14
The whole point of the new 'scheme' is I can continue to build widgets and they will automatically be uploaded to the website as soon as I save them. There is no metadata for description, therefore I can't provide it.
My suggestion is to translate the top of the website in French, then provide a link to the top item on the page, which currently is:
https://altuit.cloud/web/dbpub/markdown/MoiObjLibDontMove/mdwiki.html#!index.md#BLIVET-SQUARE
That's about best I can do.
7592.16 In reply to 7592.15
And they are input in Alphabetic order so that is not my cup of thea! :D
..but better than nothing : I open 2 screens your and mine
Rool them and when there is a difference that the new one etc...
PS You have not updated your Kitbash link in your Moi's Signature! :)
EDITED: 19 Oct 2015 by PILOU
OK Updated! :)
PS your adress Links & Images are permanent ?
7592.18 In reply to 7592.16
It may be better I just share a library via Dropbox now that Max has multiple folder support.
I will think how best to accomplish this.
I did change my sig a couple days ago, but the new sig will only apply to new messages. Try the one below.
7592.19 In reply to 7592.17
Yes, they should be permanent.
Cool! :)
7592.21
Very very nice! :)
Arian DESIGN
www.arianshamil.com
@ Chipp
your link at https://www.youtube.com/watch?v=26Hwt9P4Uzw is broken!
7592.23 In reply to 7592.22
Works here.
7592.24 In reply to 7592.23
Again...always !
Error (404)
We can't find the page you're looking for.
This one is working!
else Kitbash elements works fine in free Strata Design 3D SE 7.5 (less pricy than Keyshot! :)
http://www.strata.com/design-3d-se-our-entry-level-3d-modeler-now-free/
Export as OBJ "Ngons" from Moi!
EDITED: 4 Nov 2015 by PILOU
7592.26
OK. Now I see what you mean. Fixed. Thanks Frenchy!
7592.27
This looks super useful chip, i shall take a look!
Sam
7592.28
Very cool, thanks for sharing.
I would like to see McMaster provide that subtractable solid with their models.
Or perhaps http://masterlist.co/ could do something similar.
7592.29 In reply to 7592.13
Thanks Max,
Did try your ObjLibrary.dialog.htm and it works great. Couple points:
Line 16 is
<body>
should be
<body class="MenuBody">
Also, FOR MAC OS ONLY! as with the ObjLibrary.menu.htm file this line 106:
if ( moi.filesystem.fileExists (iconname) ) { document.write ('<div class="preview"><img class="icon" src="'+ iconname.split("\\").join('/') +'?'+randomID+'"></div>'); }
should be changed to:
if ( moi.filesystem.fileExists (iconname) ) { document.write ('<div class="preview"><img class="icon" src="file:///z:'+ iconname.split("\\").join('/') +'?'+randomID+'"></div>'); }
I've UPDATED the ObjLibrary.dialog.htm for MacOS only with the changes (see attached).
A challenger in the Poly world! ;) but not free (12 $- 100 assets )
24 vidéos hyper detailed!
EDITED: 27 May 2017 by PILOU
Show messages:  1-10  11-30  31-50
