Hi Lewis,
> BTW how does somene who is not a coder findout those codes/scripts for all tools inside
> MOI ? I'm shortcut guy so id' like to add shortcuts for all the tools like Fillet, chamfer,
> move, rotate, scale...... anythign what speeds up workflow.
> Is there "easy" visual way of doing it like in other programs where you pick tool/from list
> and hit key and that's it, or we need to write commands/code for each one ?
In the future I want to make an easier way to do it by picking things off some kind of list, but currently you have to just type in the command name or script code that you want to run. Pasting text should work in there though, what operating system are you using?
There is a list of all command names in the help topic for shortcut keys here:
http://moi3d.com/3.0/docs/moi_command_reference11.htm#shortcutkeys
Some of the most commonly used scripts are listed there too, like the "reset all views" that you had asked about previously. Also there are more scripts collected here:
http://kyticka.webzdarma.cz/3d/moi/
The shortcut key setup is definitely a fairly primitive area of MoI that needs some attention, but it's been difficult to prioritize spending much time on it so far though since it's an area that most people only go into very rarely to set up the keys. It's not something that is usually used on a daily basis, so it's been a little neglected compared to things that might actually be used frequently.
