Transparent surfaces?
All  1-2  3-7
7589.3 In reply to 7589.1
Hi Chipp - transparency for surfaces hasn't been a priority yet because of the hidden line view (View > "Display hidden lines" checkbox) which when enabled already lets you get an idea of the structure of hidden objects and also allow you to select edges and curves.
It is also possible to set objects into "faint wireframe" mode where the surfaces are hidden and the edges are displayed in a dashed style, that's what Pilou shows above.
I would like to add in an actual transparent surface mode in the future but it's hard to say when it will be implemented, because there is far more work to do to make it happen than just modifying a transparency value. In order to do a transparent display requires a lot of special attention to the draw order of polygons in the display engine, they have to be drawn in back to front order in order for the opacity to work correctly. That sorting can tend to incur a high performance cost and so it's something that has to be implemented with a lot of care, making it a fairly time intensive feature to add.
7589.4 In reply to 7589.2
PERFECT!!!
Thanks very much Frenchy :-)
7589.5 In reply to 7589.1
Hi
Is it possible to modify the texture properties of surfaces other than the diffuse colour? Can the sepcular value be adjusted?
Keith
7589.6 In reply to 7589.5
Hi Keith,
Sorry no there isn't currently any way to separately adjust the specular color of an object, that's something that you would normally do in a rendering program instead of inside of MoI.
You can enable specular highlights on or off for the display though by going to Options > View > "Lighting options".
7589.7 In reply to 7589.6
Ok
Thanks for the quick reply.
Show messages: All  1-2  3-7
