Dimension tool (as in sketchup)
 1-5  6-25  26-45  46-65  66-85  86-105  …  126-138
7403.46
Max should get some sort of "USER OF THE DECADE" award for MoI. Great job!!!
7403.47 In reply to 7403.43
Frenchy Pilou
>> Pseudo Code : When 180° > Arrow Angle > 360° reverse Position Text ...
Now it looks better :)
EDITED: 7 Mar 2022 by SMIRNOV
7403.48 In reply to 7403.47
I am confident! :)
Seems cool!
French version
http://moiscript.weebly.com/cotations.html
EDITED: 3 Jul 2015 by PILOU
7403.49
Can the output be in curves instead of surfaces?
7403.50 In reply to 7403.49
hello
formidable efficiency.
Well done guys and applause to Max !!!
Chri
7403.51
;) v.0.9 wil be soon
What a teasing! :)
7403.53 In reply to 7403.50
Very nice demo, Christian.
7403.54
Version 0.9
Added circular mode.
In fact I made it for angles, but unfortunatelly I had no free time this weekend to write that.
To enter this mode hold the control button while selecting a first point.
In this mode a length of the arrow will be locked to a circle diameter (arrow type 1-3), or radius (arrow type 4-5).
7403.55 In reply to 7403.54
Cool!
But there is a little glitch with this new Mode(with CTRL): when you make a second click on the first click!
All disapears for ever in the space dimension with also the figure! :)
EDITED: 5 Jul 2015 by PILOU
7403.56 In reply to 7403.55
Hmm, my script doesn't interact with any objects except of dimension lines. I looks like a MoI bug, caused by bug in my script (division by zero). Anyway it's my fault. I've already fixed it. I'll upload new version today evening.
7403.57 In reply to 7403.54
Please, is it possible to get the output in curves instead of surfaces? I think it's more lightweight and it's possible to export them without using hidden line removal algorithm.
Max.
7403.58 In reply to 7403.57
Hi Max, re: make curves instead of surfaces, open the file _Dimensions.htm in a text editor, and edit the line that creates the text factory. It's this one here:
var text = factory ('text', moi.VectorMath.createTopFrame(), tx, fontName, false, false, 'surfaces', textSize, 0, false);
Edit that to replace 'surfaces' with 'curves' and then it will make curve text rather than surface text.
7403.59 In reply to 7403.58
<< it will make curve text rather than surface
And for the Arrows ?
7403.60 In reply to 7403.59
I don't like this idea. If you need curves you can click Dimensions style, select all, select edges, ctrl+c, ctrl+v. It will take 3-4 seconds.
My script works correctly with surfaces only. If you change surfaces to curves, snapping will be enabled for all objects including anotations and dimension lines.
7403.61 In reply to 7403.60
No problem! :)
7403.62 In reply to 7403.55
it is better to turn outside the circle , explanation on the next POST :
il est préférable de tourner en dehors du cercle, explication dans le prochain POST:
Chri
EDITED: 6 Jul 2015 by CHRI
7403.63 In reply to 7403.62
7403.64
v.0.9a (fixed: division by zero bug)
This will be in the next version. Of course there will be degrees instead of cm.
7403.65
wastzzz
replace line: arrow = concat ( factory ('planarsrf', arrow), text);
with: arrow = concat (arrow, text);
christian
Pilou wrote about this problem. It has been fixed.
Show messages:  1-5  6-25  26-45  46-65  66-85  86-105  106-125  126-138
