Dimension tool (as in sketchup)
 1-18  19-38  39-58  59-78  79-98  …  119-138
7403.39
Hi Max,
I allowed myself to add new arrow type 4, which can be useful for various description in drafts.
Kind regards,
Mik
7403.40 In reply to 7403.39
Neat add!
French Version UpDated http://moiscript.weebly.com/cotations.html
EDITED: 1 Jul 2015 by PILOU
7403.41
This is so helpful. Thanks so much Max for your time.Theses scripts really help fill some missing features without changing the program.
7403.42
...and twin of type 4 -> type 5 :-)
7403.43 In reply to 7403.42
Does it not possible to input a test inside the code for have only a Type 4 ?
Pseudo Code : When 180° > Arrow Angle > 360° reverse Position Text ...
7403.44
it's question for MAX, I have no experiences with script writing unfortunately. I've only analysed Max's script and analogically added new arrow types.
I've only noticed that arrows are created as polylines in Cartesian coordinate system and then it makes surface from polyline.
Position of text is done by vector of direction probably when the arrow line is created (from left to right and vice versa).
BTW Type 5 is can be used for radius measurement as well. In "unit" text box it has to be paste " R| "
Mik
7403.45
Great script, Max, very useful.
7403.46
Max should get some sort of "USER OF THE DECADE" award for MoI. Great job!!!
7403.47 In reply to 7403.43
Frenchy Pilou
Now it looks better :)
EDITED: 7 Mar 2022 by SMIRNOV
7403.48 In reply to 7403.47
I am confident! :)
Seems cool!
French version
EDITED: 3 Jul 2015 by PILOU
7403.49
Can the output be in curves instead of surfaces?
7403.50 In reply to 7403.49
hello
formidable efficiency.
Well done guys and applause to Max !!!
Chri
7403.51
;) v.0.9 wil be soon
What a teasing! :)
7403.53 In reply to 7403.50
Very nice demo, Christian.
7403.54
Version 0.9
Added circular mode.
In fact I made it for angles, but unfortunatelly I had no free time this weekend to write that.
To enter this mode hold the control button while selecting a first point.
In this mode a length of the arrow will be locked to a circle diameter (arrow type 1-3), or radius (arrow type 4-5).
7403.55 In reply to 7403.54
Cool!
But there is a little glitch with this new Mode(with CTRL): when you make a second click on the first click!
All disapears for ever in the space dimension with also the figure! :)
EDITED: 5 Jul 2015 by PILOU
7403.56 In reply to 7403.55
Hmm, my script doesn't interact with any objects except of dimension lines. I looks like a MoI bug, caused by bug in my script (division by zero). Anyway it's my fault. I've already fixed it. I'll upload new version today evening.
7403.57 In reply to 7403.54
Please, is it possible to get the output in curves instead of surfaces? I think it's more lightweight and it's possible to export them without using hidden line removal algorithm.
Max.
7403.58 In reply to 7403.57
Hi Max, re: make curves instead of surfaces, open the file _Dimensions.htm in a text editor, and edit the line that creates the text factory. It's this one here:
var text = factory ('text', moi.VectorMath.createTopFrame(), tx, fontName, false, false, 'surfaces', textSize, 0, false);
Edit that to replace 'surfaces' with 'curves' and then it will make curve text rather than surface text.
Show messages:  1-18  19-38  39-58  59-78  79-98  99-118  119-138
