Select similar
7311.1
Is it any Select similar command?
My Portfolio: www.samardac.com
A lot of my Tutorials!
7311.2 In reply to 7311.1
Hi Andrei, could you be more specific about exactly what kind of similarity you are trying to target?
Like is it similar shapes? Similar styles? Similar object names?
There is a RemoveDuplicates command that can get rid of duplicated curves:
http://moi3d.com/3.0/docs/moi_command_reference10.htm#removeduplicates
7311.3 In reply to 7311.2
I need to select first of all similar edges, than may be surfaces.
7311.4 In reply to 7311.3
Also Michael, is it any local scale, rotate, move?
For example, I have a lot of profile and want to scale them local how to make it?
7311.5 In reply to 7311.3
Hi Andrei, can you give some more explanation of what you mean by a "similar edge" ?
Do you mean an edge on some other solid that is in some similar structural position as some currently selected edge? If so I don't really see how it would be possible to script that, sorry. It tends to be very difficult to code and script things that rely a lot on your own human judgement as part of the process, in order to script things you need to have a very specific formula for how the "similarity" is to be evaluated.
7311.6 In reply to 7311.4
Hi Andrei,
You could use the Randomize transform plug-in as a the basis for making a plug-in to do that. It's here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5416.5
That is set up to do randomized rotations and scales using the center of each object's bounding box as the origin point for the transform.
7311.7 In reply to 7311.6
Michael, thanks, I mean this:
7311.8 In reply to 7311.7
Hi Andrei,
Unfortunately I don't see how it would be possible to script that without making some kind of artificial intelligence pattern recognition mechanism.
7311.9 In reply to 7311.8
ok
