Hatch Fill
 1-9  10-29  30-37
7279.30 In reply to 7279.29
Yes, the closed shapes must be drawn in the top view and if you want to hatch several closed curves at once they must be all on the same Z plane.
HINT
You can hide all hatch lines In the Scene browser under Objects.
Or you can select and delete or color all hatch lines.
Thank you Michael for modding the script!
-Martin
7279.31 In reply to 7279.29
> Seems working only on the "top view" faces's object! ?
Yes, that's correct, some usage notes earlier in this thread here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7279.9
quote:
NOTE
The closed shapes must be drawn in the top view.
If you want to hatch several closed curves at once they must be all on the same Z plane.
7279.32
Last example combine with command Make2D4Views
http://moi3d.com/forum/messages.php?webtag=MOI&msg=8041.1
Chri
EDITED: 1 Mar 2021 by CHRI
Size: 391.8 KB, Downloaded: 89 times, Dimensions: 1671x941px
Very convincing!
7279.34 In reply to 7279.27
Where can I find this feature?
If the filling surface is a surface, what can we do?
thanks!
7279.35 In reply to 7279.34
Just load these files unzipped in the moi commands folder
and make a shortcut on it
write HatchItWithRotation or hatchItwithRotation or HAtchItwithRotation etc...but without space
or Press Tab and write HatchItWithRotation but without space
https://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=49a2a6271e520996f071e7324a59a40e&filename=HatchItWithRotation.zip
7279.36 In reply to 7279.27
Can you tell me how to operate it?
7279.37 In reply to 7279.36
Hi dangerhu, are you on Mac or Windows and what version of MoI are you using? That will help me to give you more precise instructions for how to install and run this plug-in script.
Show messages:  1-9  10-29  30-37
