Hi Dzeko,
> Great script but when i add _dimensions on all shape created by, the perspective have not the reel dimension :(
> i need to _dimensions make translation ^^automaticaly
The 3D view gets converted to 2D by a projection method and it's just part of how projection works that an angled projected line does not have the same length as the original line.
You can try putting in the dimension in the 3D model before you run Make2D so the dimension text and arrows are all part of the process, or if you need better dimensioning than that you should try some different CAD programs that have focused more on that specific area than MoI has as of yet. Try ViaCAD for an inexpensive solution.
