Any tricks for getting around instancing?
 1-2  3-22  23-28
7203.3 In reply to 7203.1
Hi chippwalters
You can try my vClone script.
Unfortunately it doesn't supports exact 3D orientation yet.
http://moi3d.com/forum/display.php?webtag=MOI&print_msg=6486.1
P.S. I've wrote a new version of this script. I'll post it today evening.
7203.4
Thanks. I did read where you were planning on instancing for v4. Looking forward to it! I'm up to 3 main modelers right now, Lightwave, MoI, and SketchUp. I'd rather not try and learn another one. I also own FormZ and Modo and find them both a bit harsh on the learning curve compared with MoI and SketchUp-- so I'll continue working with your program now.
Max, that does look interesting. Am I correct I can create a line segment and the vClone script will make copies everywhere it finds the correctly named line segment? If so, that's just the ticket I was looking for!
7203.5 In reply to 7203.3
Max, vClone works GREAT! Thanks a bunch :-)))
7203.6
Yep, that's a mandatory feature for me as well.
Max.
7203.7 In reply to 7203.3
Hey Max,
Is there a way to use vClone to create a 'mirror' of an object? IOW, would it be possible to check the rotation of the vector and clone using the rotation information? Just wondering. Thanks again!
7203.8 In reply to 7203.7
Just Mirror and / or Rotate your vectors first! ;)
7203.9 In reply to 7203.7
I think it's easy, but I need to make some changes in the script
7203.10
I do all my instancing of MoI generated meshes in Modo.
In sketchup you can turn the MoI generated mesh into component and then copy it around as required.
I only use MoI as stepping stone to creating a nice mesh for export to 3d art program so the ability to instance objects in MoI is not something that is important to me.
~Kevin~
7203.11
vClone 1.0
Now it supports scaling
EDITED: 7 Mar 2022 by SMIRNOV
7203.12 In reply to 7203.11
Random Scaling option ?
And where do you input the factor of scaling ?
EDITED: 26 Jan 2015 by PILOU
7203.13 In reply to 7203.12
The scale depends of vector length.
Length 1 - 1:1
Length 8 - 8:1
7203.14 In reply to 7203.8
Doesn't work for me. See the image below:
1. Originating object
2. 2 vectors. The one on the right is a mirror (use mirror command) of the one on the left. You can see when I run vClone, they are not mirrors of each other. :(
7203.15 In reply to 7203.14
How to use vclone ?
thanks
7203.16 In reply to 7203.15
7203.17 In reply to 7203.14
<< You can see when I run vClone, they are not mirrors of each other. :(
Select Vectors / Flip before VClone ;)
And you can also Oriente your object first with the Base Origin with the TriPod axes at the beginning of the Vclone!
See next post!
EDITED: 27 Jan 2015 by PILOU
<< How to use vclone ?
PS I have forgotten to align the Y axe on a very tiny gap at the bottom 's cone because I had not my glasses on the noze! :)
But I believe that you have the concept!
7203.19 In reply to 7203.18
Zut alors!
I wasn't using the base part correctly. I will try again. Thank-you!
7203.20 In reply to 7203.19
Thanks Pilou.
But how to do that as in the attachment.
Clones follow the sphere..
EDITED: 9 May 2020 by FINEMA
7203.21 In reply to 7203.20
Draw the "egdes lines" as you want on the surface of the sphere!
You can use for that another plugins of Max Smirnov
http://moiscript.weebly.com/dispersions.html (in French! ;)
7203.22 In reply to 7203.21
Thanks a lot it's perfect !
Show messages:  1-2  3-22  23-28
