ping - Max Smirnov
 1-4  5-24  25-44  45-64  …  85-87
6837.5 In reply to 6837.4
6837.6 In reply to 6837.5
Thanks but DistortCurves 0.9 seems to be different from the "Randomize Curves" script shown in the video.
6837.7 In reply to 6837.6
Yes, Pilou posted the wrong script. I have it from the cool russian MoI forum (wish i could understand Russian).
http://vk.com/moi3d
You have to scroll a bit to find it.
6837.8
I was wondering about that script myself. I scrolled down the Russian forum...saw Max, but didn't find the script. :-(
Anyone else find it?
6837.9 In reply to 6837.8
Spoke too soon. Anyone interested, scroll down to Jan 2014 postings. You will see Max's color render, with the script file.
6837.10 In reply to 6837.9
Got it thanks.
Wow while scrolling down I discovered some impressive projects.
-Martin
6837.11 In reply to 6837.10
For sure! I need to learn Russian! :-)
Ah sorry : but there was some similar in the result :) the random curves! :)
What a page!
So French Version :)
http://moiscript.weebly.com/scripts-de-max-smirnov.html
EDITED: 29 Jul 2014 by PILOU
6837.13
6837.14 In reply to 6837.13
I'm puzzled - I copied the two files into the Package Contents of MOI 3.1, and verified that they are there, but no option shows up in the program. How do I use the plugin?
6837.15 In reply to 6837.14
Make a shortcut to it http://moi3d.com/3.0/docs/moi_command_reference11.htm#shortcutkeys
or Press Tab then write the name of the plugin!
So
_RandomCurves
(don't forget the "_" ) "R" & "C" can be "r" & "c"!
EDITED: 16 May 2017 by PILOU
6837.16 In reply to 6837.14
Hi Rick, there are some instructions for installing plug-in commands here: http://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
You'll need to set up a shortcut key or type in the command name in order to trigger the newly added command.
6837.17
Hi everyone! :)
I know that I left a lot of questions unanswerred. I'm so sorry.
Now I even can't find all those questions you asked to me.
If someone wants to ask me about something, please write your questions to this thread. I'll check this thread from time to time and I'll try to answer every question as fast as possible.
Max
6837.18 In reply to 6837.17
Just 1 question from me.....
How the hell are you?
Take care!
6837.19 In reply to 6837.18
Hi BurrMan
I'm fine :) Everything is as usual. I'm working hard last months (as always) so I haven't time for MoI at all.
6837.20 In reply to 6837.17
Hi Max!!
Wow! ...it's a pleasure to see you here again!!
I hope this isn't inappropriate, but...just a simple question.
What's your main job ? What you do for a living ?
I'm a software developer.
Thanks and have a nice day.
Bye.
6837.21 In reply to 6837.20
Hi Marco
I'm lead engineer in a company which design and installs fire alarm systems, security systems, building automation etc.
In recent years my team mostly works at Moscow public transport objects (subway stations, depot).
6837.22 In reply to 6837.21
Hi Max!
Thanks a lot for sharing!
@You : "...I'm lead engineer..."
Ok. Now all it's clear :)
Now I understand why your scripts are so reliable!
Have a nice day.
6837.23 In reply to 6837.17
Hi Max,
Great to hear from you, and I am excited that you had already thought along the lines of a physics engine node/s for project elephant.
It is inconceivable what parametric possibilities this will unleash.
I can't wait...
Hi Max,
I just copied editor.css and editor.js to MoI4betaNov18.
The following script seems to work properly in MoI4beta, but maybe there is a bug in MoI3 version of the script?
In MoI3, the first time it is run, it defaults to UV mode, not U mode.
Repeat runs open in U mode.
_FxGraph3D log(u)/log(10);(v);0;1;10;-0.5;0.5;9;1;0;0;0;U
It is of very minor concern :-)
Show messages:  1-4  5-24  25-44  45-64  65-84  85-87
