ping - Max Smirnov
 1-10  11-30  31-50  51-70  71-87
6837.11 In reply to 6837.10
For sure! I need to learn Russian! :-)
Ah sorry : but there was some similar in the result :) the random curves! :)
What a page!
So French Version :)
http://moiscript.weebly.com/scripts-de-max-smirnov.html
EDITED: 29 Jul 2014 by PILOU
6837.13
6837.14 In reply to 6837.13
I'm puzzled - I copied the two files into the Package Contents of MOI 3.1, and verified that they are there, but no option shows up in the program. How do I use the plugin?
6837.15 In reply to 6837.14
Make a shortcut to it http://moi3d.com/3.0/docs/moi_command_reference11.htm#shortcutkeys
or Press Tab then write the name of the plugin!
So
_RandomCurves
(don't forget the "_" ) "R" & "C" can be "r" & "c"!
EDITED: 16 May 2017 by PILOU
6837.16 In reply to 6837.14
Hi Rick, there are some instructions for installing plug-in commands here: http://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
You'll need to set up a shortcut key or type in the command name in order to trigger the newly added command.
6837.17
Hi everyone! :)
I know that I left a lot of questions unanswerred. I'm so sorry.
Now I even can't find all those questions you asked to me.
If someone wants to ask me about something, please write your questions to this thread. I'll check this thread from time to time and I'll try to answer every question as fast as possible.
Max
6837.18 In reply to 6837.17
Just 1 question from me.....
How the hell are you?
Take care!
6837.19 In reply to 6837.18
Hi BurrMan
I'm fine :) Everything is as usual. I'm working hard last months (as always) so I haven't time for MoI at all.
6837.20 In reply to 6837.17
Hi Max!!
Wow! ...it's a pleasure to see you here again!!
I hope this isn't inappropriate, but...just a simple question.
What's your main job ? What you do for a living ?
I'm a software developer.
Thanks and have a nice day.
Bye.
6837.21 In reply to 6837.20
Hi Marco
I'm lead engineer in a company which design and installs fire alarm systems, security systems, building automation etc.
In recent years my team mostly works at Moscow public transport objects (subway stations, depot).
6837.22 In reply to 6837.21
Hi Max!
Thanks a lot for sharing!
@You : "...I'm lead engineer..."
Ok. Now all it's clear :)
Now I understand why your scripts are so reliable!
Have a nice day.
6837.23 In reply to 6837.17
Hi Max,
Great to hear from you, and I am excited that you had already thought along the lines of a physics engine node/s for project elephant.
It is inconceivable what parametric possibilities this will unleash.
I can't wait...
Hi Max,
I just copied editor.css and editor.js to MoI4betaNov18.
The following script seems to work properly in MoI4beta, but maybe there is a bug in MoI3 version of the script?
In MoI3, the first time it is run, it defaults to UV mode, not U mode.
Repeat runs open in U mode.
_FxGraph3D log(u)/log(10);(v);0;1;10;-0.5;0.5;9;1;0;0;0;U
It is of very minor concern :-)
Hi Max!
I've tested some of your nodes with V4.
Here you can find a detailed report : http://moi3d.com/forum/index.php?webtag=MOI&msg=8682.49
Ciao!
Hi Max.
Maybe you could find interesting this conversation started at http://moi3d.com/forum/index.php?webtag=MOI&msg=8667.17
We are talking about your subDiv tools :)
Ciao!
6837.27 In reply to 6837.24
Hi Brian
>>In MoI3, the first time it is run, it defaults to UV mode, not U mode. Repeat runs open in U mode.
I tested this script with 3.0(win) and 3.1(mac), and I can't reproduce this UV/U bug. :(
6837.28 In reply to 6837.25
Hi Marco
>>ERROR : Cloth.v.0.96.2014.02.23.zip (Mon Nov 3 23:56:24 2014)
Thank you, I know about this script error. I'll check it this weekend.
>>Maybe you could find interesting this conversation..
OK, I'll read it right now
6837.29 In reply to 6837.27
Hi Max,
Upon further testing: If there is a space following the final U, then the UV mode pops up, the first time only.
(I was picking up a trailing space when highlighting for Ctrl_C, Ctrl_V) (silly error)
6837.30 In reply to 6837.29
I added a command which removes all spaces from script parameters.
You can download new version of the script from my file archive.
http://moi.maxsm.net/files
Show messages:  1-10  11-30  31-50  51-70  71-87
