Hi Andrei, Loft does not have anything like "artifical intelligence" to decide between multiple different sorting possibilities, it either uses the order that you picked in or if you do some kind of group select mechanism instead of individual click selection it sorts them if they're on parallel planes by increasing distance from the lowest one, or by connecting together centroid points in a forward motion if they are not all on parallel planes.
If you need to generate a loft that has a kind of "undercut" to it, there isn't any way for a group sorting mechanism to figure that out, the way you tell Loft the order in that case is by individual click selection.
