MI 17 V5
 1-13  14-31
6028.14 In reply to 6028.13
"""""""""""""""""" I spend about 3 days experimenting and step by step I discovered way
When I find this method I made body for one day and the rest in another day, and polish model for another 1 day."""""""""""""
Key information for mortals........ :o
6028.15 In reply to 6028.14
I concur!
It's the same reason why I haven't made any tutorial videos... so you guys don't have to see the fumbles and negative steps back before a good positive solution is implemented.
Sometimes I have to try each of any alternative solution I come up with just to say I tried it.
6028.16 In reply to 6028.11
Thanks Mike!
I have to admit this is all new to me in a big way. I have been messing with the vectric Software that came with my CNC, but I just haven't been able to get those free flowing curves and recurves that are in jazz guitars and les pauls. As I mentioned in an earlier post I tried a lot of trials like Alibre, bought ViaCad and Max 3D and the UI just didn't seem intuitive, it seemed to get in the way of the drawing and experimenting. The second night i messed around with MOI I was able to create a very nice sort of undulating surface on an LP type guitar top. It was far from perfect but it made my heart race! As to all the technology behind 3D software I am a total novice. In the past I have hand built all my guitars but now want to combine my natural geekiness with my artistic side and this seems to fit the bill. And then let the CNC carve the tops and backs for the most part. Plus you guys have all contributed tons of info on the forum for me to study.
Hopefully I won't ask too many redundant questions, but you guys just point me at old threads if you don't mind and I will study up! I'm loving this so far!
John
" ... so you guys don't have to see the fumbles and negative steps back before a good positive solution is implemented"
Actually I've been watching a series of machinist tutorials on You Tube. What makes them unique is they show every mistake in their planning, how they corrected their mistakes, and how they finally produced good parts. I learn more from watching them work through the problems than I do watching a rehearsed final solution.
That's why I enjoy MoI postings from someone who doesn't get expected results, followed by experienced members posting multiple solutions.
Ed
6028.18 In reply to 6028.16
>Hopefully I won't ask too many redundant questions,..
Redundancy is a great teacher. Feel free to ask away!
Ed, so true!
And I do get to show the occasional hitch in my tutorials.
Though, it's the graphic designer in me that desires to present the more polished product.
6028.19
Well...first of all we have to keep in mind what is the target
1) model to render
2) model to 3d print
3)model to techical draw and manifacturing
First target don't need an accurate modeling,just smooth surfaces.
I saw all your models Andrei,you make the main part then just assembly the details
take a look at the screenshot where i drew red arrows:those parts are not joined..just "placed"
now try to imagine if the customer wants also the hely printed in 3D:you must have a solid..
this means not only to melt all parts together,but often also fillet most of edges
take a look at the part i highlighted in blue:is not joined and also you have the seam that surely will make problems if filleted.
You don't care of all this things because you'll use this hely for 2D images..and you'are right !!
<<Moi is a tool..just depends by technique>>
I still support idea that here we can do ALMOST everything
I did a lot of complex objects with MOI and also "NOT-CAD" stuff ( pineapple..baguettes..recentely also banana plants..)
Most complex surface i did was front part of 500 Abarth
i spent a month to get that shape,and i knew it wasn't feasible here
Now i say to myself:"Mauro..you are a stupid to insist to get that kind of shapes"
I'm a industry mechanic and manteinance,so i work manually
Firts rule is always to use right tools for assembly-disassembly
i know..you can use the hammer to disassembly a bearing instead of the manual press...
when i did that part of 500 in MOI,i used "the hammer"...because..."i didn't have the press"(the right tool)
That's the reason why i never stop to dream that,soon or later, - "The Messiah" - (T-Splines or something like that) will appear in MOI "to save us" !! :)
Leave critics and weird thoughts apart..let me say to you,Andrei,all my compliments for your renders:Bravissimo!
M
EDITED: 14 Jul 2013 by M-DYNAMICS
6028.20 In reply to 6028.19
Thanx m-dynamics,
Yes you are right I made it for render and may be animation, so I can allow to my self not to spend time fixing those things you are marked. Just leave them as they are)
But If it have to be printed on 3D printer, it could be fixed.
Good work with the car)
6028.21 In reply to 6028.20
Or, he 3d prints the parts as they are, then the little guy orders a kit and gets out his drill and glue and final assembles his "80 percent" Heli!!! :o
6028.22
Top work
Message 6028.23 deleted 16 Jul 2013 by ANDREI SAMARDAC
6028.24
Hay people I just finished tutorial, check it here: http://moi3d.com/forum/messages.php?webtag=MOI&msg=6034.1
6028.25
Samardac,
Thanks for those tutorials, just spent the better part of two hours watching you build that 747, incredible stuff! I feel about 1000% more comfortable building organic shapes after watching your method.
Now to get a blueprint of a 747 and actually walk through it step by step alongside you.
Really appreciate the time and effort you put into that...
Ryan.
6028.26 In reply to 6028.25
Thank you The Mad Hatter,
After I elaborate this method I also feel more confidence in making organic shapes in MOI)
6028.27 In reply to 6028.25
@Mad Hatter :
Better get an Airbus. Too many issues with "Made in the USA". AOG is too often with Boeing nowadays. ;)
Careful Ditto - Both Michael and I are in the Seattle Washington area, under the shadow of Boeing :)
Ed
6028.29 In reply to 6028.28
Aha ha ha))
Portfolio: www.samardac.tumblr.com
6028.30 In reply to 6028.29
Bits Of Engines In Neighbours Gardens
Martin Spencer-Ford
6028.31 In reply to 6028.28
Hehe ;)
Just protect yourselves. Wear helmets! The overall empty weight of a Dreamliner is 259,500 lb (118,000 kg). Hope the shadow you are referring to don't fall on your head. Chances are, though, they do.
It was nice talking to you.
Show messages:  1-13  14-31
