Union problem
All  1-2  3-14
5764.3 In reply to 5764.2
No all objects are solids, check the attachments. And I also include in this project another example. Thanx.
EDITED: 20 Jul 2013 by ANDREI SAMARDAC
5764.4 In reply to 5764.1
Hi mir4ea, thanks for attaching the model, I could have sworn I did not see it at first!
So it looks like all that I wrote above was incorrect, you do have all solids here - it looks like it's getting confused with handling the edges that are overlapping right on top of each other, normally that's more of an issue when the pieces are maybe slightly skimming each other a little bit and not as much of a problem when they are very exactly on top of each other but it looks like in your case here there's some bug where it's still getting confused about how to deal with the edges and seams that are stacked on top of one another.
If you rotate the spheres so that the "seam edge" of the sphere is inside the cylinder rather than resting right on the cylinder's own edge, it will behave better in this case, see attached example.
I would have thought though that your initial example should work since it looks like things are meeting very precisely, there is probably some kind of bug involved there but probably not an easy one to fix without potential side effects.
5764.5 In reply to 5764.3
Hi mir4ea,
The "X" one in your second attachment is a different problem - that's a problem in the surface/surface intersector in handling singular "crown point" intersections. It's probably the biggest remaining surface/surface intersection bug that's in the geometry library.
You get the result you see there because all the intersections are not being generated, if you select the pieces and use Construct > Curve > Isect you'll see it only finds 3 of the intersections and is missing one.
I'm hoping at some point to get this fixed in the geometry library, it's a delicate area to mess around with though.
5764.6 In reply to 5764.5
Thanx Michael,
Yes you are right, rotating the sphere solve this problem.
About X, wanted to mention that in 90 degree rotation it union well.
Thanx.
5764.7 In reply to 5764.3
Also the X one will actually work right if you get true analytic cylinder surfaces created, that's because the analytic cylinder/cylinder intersector will avoid this particular bug that's in the general purpose surface/surface intersection method.
So if you try in the attached example it should work.
5764.8 In reply to 5764.3
Hi mir4ea, also your original one with the cylinder and spheres in their original locations, the cylinder is not being recognized as an analytic cylinder.
Are you possibly building these cylinders by something like sweeping a circle rather than by extrusion or by draw solid > cylinder?
5764.9 In reply to 5764.7
"analytic cylinder" you mean - cylinder created from draw solid menu?
5764.10 In reply to 5764.9
Yes, I created it by sweep.
5764.11 In reply to 5764.9
Yeah, or also extrusion of a circle will generate one also - if you turn on the control points of the sweep-constructed cylinder you'll see it has 4 control points in the straight direction instead of it only being 2 points in the straight direction. Basically sweeps are focused on making curvy shapes and go through a refinement/fitting process as part of the construction, one byproduct of that is that the surface will always be a cubic in that direction.
Extrusion or draw solid > cylinder make a more basic cylinder that also will be a special class of surface that can generate more precise results for some kinds of intersections.
5764.12 In reply to 5764.11
Thanx for clear Explanation.
This is the screen of control points first extruded, and second by sweep.
I can not see 4 points in stright direction on sweeped cylinder, may be I did something wrong?
5764.13 In reply to 5764.12
Hi mir4ea,
You're only seeing the control points on the curves there (the line and the circle you used as inputs to make the sweep), not any surfaces. In order to turn on control points of surfaces that are joined at trimmed edges you need to use Edit > Separate to break them into separate pieces and then you can turn on points. See here for more info on that:
http://moi3d.com/wiki/FAQ#Q:_Why_does_show_points_work_for_some_objects_but_not_others.3F
5764.14 In reply to 5764.13
Got it thanx.
Show messages: All  1-2  3-14
